Annotate Selected Features
969
07-10-2013 09:56 PM
by Anonymous User
Not applicable
Basically what I want to do is annotate selected pipe. The function is similar as ArcMap COTs function. (Select feature in ArcMap, right click layer name in TOC and select ???Annotate Selected Features???)
I have a pipe feature layer and pipe_Anno layer which is feature linked. AnnotateLayerProperties had been custom previously. If I run ArcMap COTs function, annotation can be popped up.
Firstly, I can get AnnotateLayerProperties and then related Symbol setting, I can create an new feature and put this feature in pipe_Anno layer with related symbol setting, everything is fine except feature location, because I want to put this feature at start/end point of this pipe and all of these setting has been done in Annotation layer properties by ArcCatalog.
Then I checked the ESRI help and tried below code:
IAnnotateFeature2 pAnnotateFeature = new AnnotateFeatureClass();
IMapOverposter pMapOverposter = m_Map as IMapOverposter;
IGraphicsContainer pGraphicsContainer;
IBarrierCollection pBarrierCollection;
pBarrierCollection = m_Map.get_Barriers(m_MxdDocument.ActiveView.Extent) as IBarrierCollection;
IElement pPlacedElement=null;  IElement pUnplacedElement=null;
pAnnotateFeature.Label(pMapOverposter.OverposterProperties, pAnnotateLayerProperties, pSelectedFeature, m_MxdDocument.ActiveView.ScreenDisplay as IDisplay, m_Map.SpatialReference, pBarrierCollection, out pPlacedElement, out pUnplacedElement);
The reason is I want to get Element based on custom setting, unfortunately I got error as "Attempted to read or write protected memory. This is often an indication that other memory is corrupt";
Is there something I am missing? Or is there a way can help me find the suitable annotation location based on setting?
Thank you for your help.
Regards,
Bing
by Anonymous User
Not applicable
Anyone did this before? much appreciate for your help.
by Anonymous User
Not applicable
finally I found the reason.
Before I do annotation, i have to detect LabelEngine, previous code just works for ESRI default label engine, if the label engine is Maplex, I have to use MaplexAnnotateFeatureClass. thanks to everyone.
Alber_Verster
good job!
