ArcGIS server and Teradata
1915
07-10-2013 07:50 AM
VadivelanPalanichamy
Hi,  we are planning to use ArcGIS 10.1 or latest Server with Teradata to publish the maps, using javascript api or other.
I am not able to find any good documentations on this Arcgis server + Teradata.
If you have worked in this area, could you give me your suggestions, where you faced problems or how easy it is ?
Vadivelan. P
BP
I am looking for the same info.
In Esri ArcMap I see how to connect to a Netezza, Oracle, SQL Server databases, but I don't see a selection for Teradata.
Is it not possible to use Esri ArcMap with a Teradata database?
DerekLaw
Esri Esteemed Contributor
Hi BP,
Support for spatial type data in a Teradata database is coming with the ArcGIS 10.2 release,
Teradata and ArcGIS
Hope this helps,
