heatmap.js based on the attribute
882
07-01-2013 07:32 PM
VadivelanPalanichamy
I am trying to use heatmap.js in my project (with Arcgis 10.1 server).. as per the samples given in the ESRI site http://blogs.esri.com/esri/arcgis/2012/09/26/heat-up-your-webmaps/
everything works fine. I created a point map service, that is also working fine. But these are all based on the cluster of points.
in the above link, there is an example, var data = [ { attributes: { count:50 }, geometry: { spatialReference: {wkid: 102100}, type: "point", x: -13625078.0408, y: 4548494.332400002 } },
I would like to modify the map service and I want to display the heat map based on that value, instead of cluster of points.
any help or idea, how to tweak this, (the original sample is http://tmappsevents.esri.com/stage/heatmap/index.html)
