Error message for the buffer tool
1970
5
06-25-2013 01:49 PM
ShikoNjuno
Hi folks
I'm having issues troubleshooting an error message while trying to set my buffer parameters.
The intention is to create a selection criteria on an ArcGIS Map to generate areas that are 1000 feet around any major roads.
I have already defined roads as a variable, and the following is the tool parameter that I'm trying to input, which sets the optional dissolve parameter to ALL , so that overlapping buffers are dissolved:
buffer = arcpy.Buffer_analysis(roads, "in_memory/buffer", "1000 Feet", "", "", "ALL")
Now I keep getting an error message with the word buffer highlighted but I don't know what's wrong. Also, as I type the word buffer in the IDLE screen it turns purple. Does this mean it has some kind of internal definition or something?
DavidAllen
Hi folks
I think buffer is a key word and you can't use it for layer names. Can you try "in_memory/buffer_roads" ?
ShikoNjuno
You know I think I may have other issues going on because it doesn't matter what I name that variable...it still comes out highlighted as an error.
Could it be that for 10.1 version the syntax is different, in that I don't have to define a variable?
ChrisSnyder
Honored Contributor
Try running the buffer tool without the dissolve "ALL" option:
buffer = arcpy.Buffer_analysis(roads, "in_memory/buffer", "1000 Feet")
Does it work?
ShikoNjuno
I did....and it still takes me back to that error point.
I'm also now calling the variable 'buffer_'.
I guess I need to look at the entire script prior to this point to see if there's syntax that's throwing off the program.
Thanks guys
ChrisSnyder
Honored Contributor
The word 'buffer' is not a keyword in Python. See: http://forums.arcgis.com/threads/4679-Buffer-error?p=21932&viewfull=1#post21932
