Is it necessary to enable SSL if the ArcGIS Web Adaptor forwards request 2 ServerSite
4447
06-25-2013 07:43 AM
JanieGoddard
If we install the ArcGIS Web Adaptor on our Enterprise Web Server and have it forward requests to our internal ArcGIS Server site, is it necessary to enable SSL? I understand security is enabled on ArcGIS Server 10.1 now at install. That was not the case in 10.0. Is it necessary to go to SSL for the Web Adaptor to access the ArcGIS Server Site?
I just read this and was concerned:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Enabling_SSL_on_ArcGIS_Server_when_accesse...
Thanks for help,
Janie
BubbaHey
You don't need SSL for web adaptor. Some orgs require it, if so follow this procedure in the help link you posted:
Enabling SSL on ArcGIS Server when accessed through the ArcGIS Web Adaptor
http://resources.arcgis.com/en/help/main/10.1/index.html#//015400000600000000
BubbaHey
JanieGoddard
Thanks! I was hoping if I use the ArcGIS Server security store, I wouldn't need the SSL.
Thanks, Janie
AnthonyGiles
Honored Contributor
Janie,
If you just use the arcgis security store your login details will be passed in clear, if you are concerned about this you need to use SSL or digest to encrypt the log in messages, see:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Securing_ArcGIS_Server_communication/01540...
Regards
Anthony
