arcpy.Describe file not found!
1096
06-19-2013 05:06 PM
JayDub
Hi all,
I'm running Python using WSGI under Wamp. The user uploads a shapefile to my server then I try to run arcpy.Describe and even though os.path.exists(...) says the file exists, arcpy it telling me that the file doesn't exist. Is there any particular reason why this would happen?
Also, if I run the same function from the console (instead of via the browser), arcpy is able to magically find the file. I'm using an absolute path to the file and I'm not using arcpy.env.workspace at all.
curtvprice
Hi all,
Are you specifying the path correctly (to handle backslashes)?  Ie using r"" or "\\" or "/"?
ShaunWalbridge
Have you confirmed that the WAMP environment is running against the same Python interpreter as ArcGIS, and can you perform any other operations successfully? Note that ArcGIS for Server is required for network-based access to ArcGIS.
