Add Fields
849
05-30-2013 11:38 PM
NilsLandmeyer
is it possible with a phyton code to add more than 1 Field to a Table?
I have to calculate a few Fields in the Modelbuilder and would like to add these new Fields at once.
Best regards,
nils-demian
MarcEngelsma1
Nils,
It's possible but I'm not sure it's faster or easier than adding a few more tools in modelbuilder.
I'd put the field names in a list and then you can loop the AddField command through that list. I'm not yet sure how you can handle different datatypes for the fields though. With all fields of the TEXT type it would look like this
Shapefile = r"C:\xxx\xxx\your shapefile here.shp"
FieldList = ["Field1", "Field2", "Field3", "etc"]
for Column in FieldList:
    arcpy.AddField_management(Shapefile, Column, "TEXT")
You can add more parameters after the field type to determine the field length, precision, etc
Hope this is helpful.
Marc
NilsLandmeyer
Thanks Marc !
best regards
nils-demian
TimDine
It isn't going to save you many characters of code, but if you wanted to expand your array idea make it a multi dimensional array or an array of objects.  Instead of a string for a field name you have an array, the items in the array could be the parameters for your add field.
FieldList = [["Field1","TEXT"], ["Field2","DOUBLE"]]
    arcpy.AddField_management(Shapefile, Column[0], Column[1])
