AddMessage question
5405
16
05-24-2013 01:03 PM
AmyKlug
How would you do this using AddMessage instead of print and in a script tool? My code has a parameter and where_clause in the search cursor so the user inputs a name and I would like a message listing field values.
ESRI expample:
import arcpy # Open a searchcursor #  Input: C:/Data/Counties.shp #  Fields: NAME; STATE_NAME; POP2000 #  Sort fields: STATE_NAME A; POP2000 D rows = arcpy.SearchCursor("c:/data/counties.shp",                           fields="NAME; STATE_NAME; POP2000",                           sort_fields="STATE_NAME A; POP2000 D")  # Iterate through the rows in the cursor and print out the # state name, county and population of each. for row in rows:     print("State: {0}, County: {1}, Population: {2}".format(         row.getValue("STATE_NAME"),         row.getValue("NAME"),         row.getValue("POP2000")))
T__WayneWhitley
Honored Contributor
This is kind of an important detail, easy to overlook, so I'm posting once more to clarify (hopefully).
Since this was a file gdb (as hard-coded in the script) and using GetParameterAsText for the var LID to 'filter' the search cursor, this query should work:
rows = arcpy.SearchCursor("C:/Python/Python.gdb/Counties", "LINE_ID = '" + LID + "'")
There's more than 1 way to enter a query, but basically from the webhelp topic, Specifying a Query in Python (http://resources.arcgis.com/en/help/main/10.1/index.html#//002z0000001r000000), a better recommended approach is something like:
qry = """%s = '%s'""" % (arcpy.AddFieldDelimiters(fc, "LINE_ID"), LID)
rows = arcpy.SearchCursor("C:/Python/Python.gdb/Counties", qry)
Hope that at least sums up better this rather lengthy thread --- for those still unsure what was happening, the incorrect query ("LINE_ID = 'LID'") was returning an empty set hence no messages...nothing to print.
Enjoy,
Wayne
T__WayneWhitley
Honored Contributor
...for 'print' substitute 'arcpy.AddMessage' with the message enclosed in parenthesis.  Just make sure your indention is correct.
As in:
arcpy.AddMessage("State: {0}, County: {1}, Population: {2}".format(row.getValue("STATE_NAME"), row.getValue("NAME"), row.getValue("POP2000")))
I think that will work...test it out.
AmyKlug
I did try that but it will run the code but will ignore the "AddMessage"
T__WayneWhitley
Honored Contributor
Any error messages?  ...you have to run this as a script tool via ArcGIS's toolbox to 'port' it to it's geoprocessor interface.  You don't have to define any parameters, but must display it's dialog window to see the returned messages - of course if erroring out before you get to the messages you've attempted to add, then you won't see them.
If the message itself is a problem, then try formatting the text before you add it to the AddMessage parameter...debatably easier to read the code that way anyway.
...as in:
theMessage = "State: {0}, County: {1}, Population: {2}".format(row.getValue("STATE_NAME"), row.getValue("NAME"), row.getValue("POP2000"))
arcpy.AddMessage(theMessage)
Again, make sure you don't have an indention error earlier in the code block.  If you're still having problems, include more complete details what you are doing and any feedback messages.
AmyKlug
I took your advice and got it to work like this:
import arcpy
LID = arcpy.GetParameterAsText(0)
rows = arcpy.SearchCursor("C:/Python/Python.gdb/Counties", "LINE_ID = 'LID'")
for row in rows:
    row.getValue(rows)
theMessage = "State: {0}, Name: {1} , Population: {2}".format(
del rows, LID
I needed to define "theMessage" without indentation and add row.getValue(rows) instead under "for row in rows".
THANK YOU!!!!!!!!!!
AmyKlug
import arcpy
for row in rows:
    row.getValue(rows)
del rows, LID
THANK YOU!!!!!!!!!!
OK this worked while I was in my other MXD but now since I have opened a new mxd it is telling me the same error that the row.getvalue(State_Name) "row" is not defined. arrrrggggg!
It wont work again in any mxd.
EDIT: I think the reason it was working is because to make sure the fields would print i ran the print code first (see my first post) and that is where it was getting it's "row" definition
T__WayneWhitley
Honored Contributor
Amy, that code makes no sense - should fail at:
row.getValue(rows)
...because 'rows' is your cursor object, not a field name -- try this, your code corrected from above - you must have the correct county feature class to run this on:
import arcpy
for row in rows:
     theMessage = "State: {0}, Name: {1} , Population: {2}".format(row.getValue("STATE_NAME"), row.getValue("NAME"), row.getValue("POP2000"))
del rows, LID
Careful with indention!
Enjoy,
Wayne
EDIT:  Or, if this helps you, the backslash is to Python a 'line continuation' character, meaning what you see in italic text should be a single line of code, expressed below perhaps easier-to-read:
for row in rows:
     theMessage = "State: {0}, Name: {1}, Population: {2}".\
                     format(row.getValue("STATE_NAME"), \
                            row.getValue("NAME"), \
AmyKlug
Whenever I use arcpy.AddMessage indented under "for row in rows" it just gets ignored and no message appears even though the code runs without error
import arcpy
for row in rows:
row.getValue("NAME"),row.getValue("POP2000"))
del rows, LID
Edit: my code looks different when posted. might be having formatting issues
The "print" version works fine in the python window so I am assuming my feature class is ok.
T__WayneWhitley
Honored Contributor
I edited my response above because I was having trouble formatting my message...
Do you have a script tool?  Are you running the code from the toolbox?  Try editing the script tool py you are using, pasting in the portion from above...again, if there's a problem, I need to know what the error messages are.
Of course if not running from ArcToolbox, then of course you won't see the messages.
Hope that helps.
Wayne
AmyKlug
Hope that helps.
Wayne
I tried that and same thing and pasted that code in (yes, running and editing from toolbox with a script tool). No error or message 😞
