Numeric Values for the Field of Type in the ProjectPoint layer?
2212
05-20-2013 06:03 AM
ShuhaiZheng
In the ProjectPoint layer, the HyElemType field has values for Diversion, Junction, Reservoir, Sink and Source. Can anyone let me know what are the corresponding numeric values in the field of Type?
I created a BatchPont layer representing reservoirs. After running he Batch Subbasin Delineation, those points were added into the ProjectPoint layer as "Junctions". I wonder if I can rename them back as "Reservoirs". I used Field Calculator to assign "Reservoir" to HyElemType field, but don't know if the Type field also needs to be changed and what value needs to be. The numeric value for a Junction is 15.  Thanks.
ChristineDartiguenave
For GeoHMS, Type = 5 for Reservoir and 6 for Diversion.
Christine Dartiguenave
Esri Water Resources Team
ShuhaiZheng
Christine,
Thank you very much for your answer!
I figured out "5" was the value for reservoir this morning by accident. I am glad my HMSNode layer contains those reservoir nodes, and hope I will spend less time in defining them in HMS.
