Using the Map Printing Sample
1323
05-11-2013 10:47 PM
ArielLomes
I'm trying to use the Map Printing Sample shown here.
However, it gives me all sorts of referencing and dependencies issues.
I'm using Visual Studio 2010 on a 64bit Win 7.
Did anyone manage to run it successfully?
Also, is there anyway to run it from the ArcGIS Runtime SDK for WPF Sample Application? I haven't seen anyway to add samples to that application.
ArielLomes
I get this error:
[ATTACH=CONFIG]24226[/ATTACH]
Which says the following:
Could not load file or assembly 'ESRI.ArcGIS.Client.Local, Version=10.1.0.0, Culture=neutral, PublicKeyToken=29c6dd6e8553d944' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
And if I try to load ESRI.ArcGIS.Client.Local again, it just goes on and on repeating to other referenceses with the same errors. If I replace all of them, it just gives about 40 or so errors.
ArielLomes
Ok solved the issue.
I accidently referenced some of the dependencies from an older version (1.0) and some from (1.0.1.1) which caused the conflict.
Now it works perfectly.
