AddField Failed to Execute???
6059
11
04-30-2013 12:59 PM
MichelleCouden1
I am trying to join 2 fields in one layer which is a shapefile and join 2 fields in another layer which is a gdb. I think I have the coding right but it is not wanting to add my join field in my shapefile. It gives me a failed to execute AddField on the first one which is the shapefile. Any hints as to what might be wrong??
import arcpy, traceback
from arcpy import env
mxd = arcpy.mapping.MapDocument("CURRENT")
# Join Fields
fc = 'K:\TASS\4_MAPPING_DATA_SUPPORT\Traffic_Mapping\Traffic_Count_Data\2011_Counts\2011_Annual_Stations\Annual_Stations_2011.shp'
env.workspace = 'K:\TASS\4_MAPPING_DATA_SUPPORT\Traffic_Mapping\Traffic_Count_Data\District_Labels_Folder\Abilene_Labels.gdb'
fields_to_join = ['!F2011_TRAF!', '!FLAG!']
arcpy.AddField_management(fc, 'COUNT', 'TEXT')
arcpy.CalculateField_management(fc, 'COUNT', ''.join(fields_to_join), 'PYTHON')
fields_to_join = ['!TextString!', '!TFLAG!']
arcpy.AddField_management(inFeatures, 'TRAFFIC', 'TEXT')
arcpy.CalculateField-management(inFeatures, 'TRAFFIC', ''.join(fields_to_join), 'PYTHON')
lstLayers = arcpy.mapping.ListLayers(mxd)
MichelleCouden1
Some more information. It says it doesn't like my shapefile which is defined at fc. Is there something I need to do to the shapefile for it to add a field??
ChrisSnyder
Honored Contributor
Do you mean join (as in a tabular join) or string concatenattion (as in join the text strings 'A' and 'B' so that the new value is 'AB')?
I think you mean the latter, so try something like:
arcpy.CalculateField_management(inFeatures, 'NEWFIELD', str(!FIELD1!) + str(!FIELD2!), 'PYTHON')
The Python .join method is for Python-specific strings, which is very different than the ArcGIS tabular concatenation I think you wanting to implement. For example:
list = ["A","B","C"]
print "-".join(list)
>>> A-B-C
BTW: You second to last line in your code: arcpy.CalculateField-management needs to be arcpy.CalculateField_management (underscore not a dash). Also, I see you have cleaned up your path names - that's looks way better! Although if I were you, I would get rid of the '4_MAPPING_DATA_SUPPORT' name (don't start a folder name with a number)! If you are interested, here's some aditional unsoliced 🙂 advice pertaining to GIS naming conventions: http://forums.arcgis.com/threads/21526-Trouble-with-Feature-Datasets-in-directories-with-spaces?p=13...
ChrisSnyder
Honored Contributor
Sorry - per your actual question: No, there's nothing wrong with the way you are adding the "COUNT" field that I can see.... Unless you already have a field called "COUNT"... Shapefiles do have a limit on the field name lenth (10 character max), but you are not exceeding that... Also, there are a handfull of "reserved" field names you cannot use since they mess with the underlying RDBMS stuff. Forget what those are off the top of my head, but I verified that "COUNT" was not one of them (at least for shapefiles).
MichelleCouden1
Yes, I am trying to make 2 fields into 1 so I can compare different values between two layers. For Example, Flag will combine with 2011_Traff to make 1 field with both values. I made the correction in my calculate field but now I'm getting an error of invalid syntax in line 20 which is my calculate field line.
# Join Fields
#fields_to_join = ['!F2011_TRAF!', '!FLAG!']
arcpy.CalculateField_management(inFeatures, 'COUNT', str(!F2011_TRAF!) + str(!FLAG!), 'PYTHON')
#fields_to_join = ['!TextString!', '!TFLAG!']
arcpy.CalculateField_management(inFeatures, 'TRAFFIC', str(!TextString!) + str(!TFLAG!), 'PYTHON')
flayer = arcpy.mapping.ListLayers(mxd, "AADT")[0]
alayer = arcpy.mapping.ListLayers(mxd, "AADTAnnoLabel")[0]
# Search Joined
FRows = arcpy.SearchCursor(flayer)
ARows = arcpy.SearchCursor(alayer)
ffields = arcpy.ListFields(flayer, "COUNT", "String")
afields = arcpy.ListFields(alayer, "TRAFFIC", "String")
FList = []
AList = []
for row in FRows:
    Fvalue = row.getValue("COUNT")
    FList.append(str(Fvalue))
for row in ARows:
    Avalue = row.getValue("TRAFFIC")
    AList.append(str(Avalue))
matched = set(FList) & set(AList)
for x in matched:
    exp = '"TRAFFIC" = ' + "'" + x + "'"
    arcpy.SelectLayerByAttribute_management("AADTAnnoLabel", "ADD_TO_SELECTION", exp)
    arcpy.SelectLayerByAttribute_management("AADTAnnoLabel", "SWITCH_SELECTION")
MichaelVolz
Esteemed Contributor
Might this line of code:
Need to be something like:
arcpy.CalculateField_management(inFeatures, 'COUNT', 'str(!F2011_TRAF!) + str(!FLAG!)', 'PYTHON')
I put quote around the calculated expression.
ChrisSnyder
Honored Contributor
Woops - yes the expression must be in a string format of course, so
is correct.
MichelleCouden1
I'm sorry Chris!! I'm trying to understand. I throw up my hands. It keeps saying it doesn't like my shapefile (Error Attached). I've checked the spelling and location 4 times and I see nothing wrong.
MichaelVolz
Which AddField statement is it failing on?
Where is the variable inFeatures defined in your script?
MichelleCouden1
I saw it. It was stopping at the veri first AddField. I went back to the help desk printout. Sorry, inFeatures was supposed to be defined because it is the in_Table name. I think I also see that my fc (which is my shapefile) I need to define the in_table for that as well. So my command should change to:
inFeatures = "AADTAnnoLabel"
Table = "AADT"
arcpy.AddField_management(Table, 'COUNT', 'TEXT')
arcpy.CalculateField-management(inFeatures, 'TRAFFIC', 'str(!TextString!) + str(!TFLAG!)', 'PYTHON')
