AcGIS Engine 10.1 Mouse Wheel zooming
2773
04-08-2013 02:56 PM
ScottMcNeil
I need change the default behavior of the map control in (.Net app) of the mouse wheel for zoom in/out-- default is roll forward to zoom out, and I need roll forward to zoom in.  In 9.3.1, I was able to change the behavior using the registry setting found in this thread
http://forums.esri.com/Thread.asp?c=159&f=1707&t=263532
however this does not seem to work for the latest version.  Anyone know how to resolve this?
TIA
ScottMcNeil
I should add that I can reverse the zoom direction in ArcMap 10.1 using the options setting, but this has no affect on zoom behavior in the  Arc engine application (not that this is a viable option-- just thought there may be a new registry value that might be useful).
ScottMcNeil
ESRI finally provided the answer to this.  The registry setting is in a different location, but works the same as before.
HKEY_CURRENT_USER_\Software\ESRI\Engine10.1\ArcMap\Settings
add DWORD value, ReverseMouseWheel = 0
