Filter
1120
04-08-2013 04:41 AM
EricWalters
Good morning
I am using my trial account of ArcGIS online - and have added the following layer to a map:
http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hurricanes/NOAA_Tracks_1851_2007/MapServe...
However, I cannot seem to be able to do a filter or query.  Under content, Filter does not appear.
Any ideas?
Eric Walters
RobertBorchert
Honored Contributor
No filtering with ArcGIS online.
However, if you open the map in ArcGIS Explorer Online  you can create queries.
Also, if you use the option to Open with ArcGIS Desktop 10 it will create a feature package which can be opened on your desktop and used just like ArcGIS
Good morning
Any ideas?
Eric Walters
KellyGerrow
Esri Alum
Hi Eric,
Filtering is available in ArcGIS Online web maps now. In order to filter a feature in the web map, it will need to be added as a feature layer.
Try adding the following link to your web map:
The filter option will be available if you click the arrow button beside the feature layer in the contents window.
Cheers,
Kelly
