Storytelling Compare web mapping application no longer loads
3242
04-09-2013 08:42 AM
MathewLevine
I get the error ""Unable to create map:response is not defined" when I try to load a storytelling compare web mapping application.  It had been working correctly for months up to this point.  None of the underlying data has been changed/deleted.  None of the permissions for the underlying data has changed.  Any ideas?
Web mapping app:  http://tnc.maps.arcgis.com/apps/Compare/storytelling_compare/index.html?appid=0babb892e45c4eca87c164...
MikeMinami
Esri Notable Contributor
There is no problem with your web map. Unfortunately, the template application is not working correctly and displays only 1 web map. The current plan is to fix this with our next update at the end of the month.
Alternatively, you can download the attached version of the template and host it on your own web server...
Mike
