sourceFCCur = arcpy.UpdateCursor(SourceFCPath) for sourceFCRow in sourceFCCur: targetFCCur = arcpy.UpdateCursor(TargetFCPath) for targetFCRow in targetFCCur: if targetFCRow.ID == sourceFCRow.ID: sourceFCDate = sourceFCRow.getValue('LASTMODIFIED') targetFCDate = targetFCRow.getValue('LASTMODIFIED') if sourceFCDate != targetFCDate: targetFCCur.updateRow(targetFCRow) del targetFCCur
Solved! Go to Solution.
targetFCCur = arcpy.UpdateCursor(TargetFCPath) for targetFCRow in targetFCCur: ... nothing with targetFCRow done here ... targetFCCur.updateRow(targetFCRow)
import arcpy source = "E:/test.mdb/src" target = "E:/test.mdb/trg" # cursor for sourceFC s_rows = arcpy.SearchCursor(source) # Dictionary for sourceFC´s fields sDict = {} # field names of sourceFC/targetFC, excluding Shape and OID fList = [a.name for a in arcpy.ListFields(source) if a.name not in ("OBJECTID","Shape")] # fill the sourceFC Dict(OIDs as keys) with dictionaries of its fieldnames/values for s_row in s_rows: sDict[s_row.OBJECTID] = dict((k,s_row.getValue(k)) for k in fList) del s_row,s_rows # update cursor for targetFC t_rows = arcpy.UpdateCursor(target) for t_row in t_rows: # compare the current row's field with the corresponding one from the sourceFC-dict # if values differ, update all target fields with sourceFC-dict´s values if t_row.LASTMODIFIED != sDict[t_row.OBJECTID]["LASTMODIFIED"]: for fName in fList: t_row.setValue(fName, sDict[t_row.OBJECTID][fName]) t_rows.updateRow(t_row) del t_row,t_rows
import arcpy source = "E:/test.mdb/src" target = "E:/test.mdb/trg" # cursor for sourceFC s_rows = arcpy.SearchCursor(source) # Dictionary for sourceFCs fields sDict = {} # field names of sourceFC/targetFC, excluding Shape and OID fList = [a.name for a in arcpy.ListFields(source) if a.name not in ("OBJECTID","Shape")] # fill the sourceFC Dict(OID as key) with dictionaries of its fieldnames/values for s_row in s_rows: sDict[s_row.OBJECTID] = dict((k,s_row.getValue(k)) for k in fList) # get point coordinates from the shape field and put them into the dict s_pnt = s_row.Shape.getPart() sDict[s_row.OBJECTID]["GEO"] = (s_pnt.X,s_pnt.Y) del s_row,s_rows print sDict # update cursor for targetFC t_rows = arcpy.UpdateCursor(target) for t_row in t_rows: # compare the current row's field with the corresponding one from the sourceFC-dict # if values differ, update all target fields with sourceFC-dicts values if t_row.LASTMODIFIED != sDict[t_row.OBJECTID]["LASTMODIFIED"]: for fName in fList: t_row.setValue(fName, sDict[t_row.OBJECTID][fName]) # replace point coordinates of shape field with values from the sourceFC-dict t_pnt = arcpy.Point(sDict[t_row.OBJECTID]["GEO"][0],sDict[t_row.OBJECTID]["GEO"][1]) t_row.setValue("Shape", t_pnt) t_rows.updateRow(t_row) del t_row,t_rows
