Loop inside a loop or Nested Loop in VBA
7572
28
04-05-2013 05:07 AM
MichelleCouden1
I need help with a loop. I need it to do 2 things and I'm not sure how to write  a double loop. Would my code look like this :
If cboStations.Text = "Urban" then
   If cboYears.Text = "2010" then
    cboDistricts.AddItem "Abilene"
KenBuja
MVP Esteemed Contributor
Try this. This will change the values of your districts if you select a new year or a new station.
Private Sub UserForm_Initialize()      Dim x As Integer      For x = 2010 To 2015         cboYear.AddItem x     Next         cboStations.AddItem "Annual"     cboStations.AddItem "Urban"      End Sub  Private Sub cboStations_Change()      If cboYear.Value <> "" Then         UpdateDistrict     End If      End Sub  Private Sub cboYear_Change()          If cboStations.Value <> "" Then         UpdateDistrict     End If      End Sub  Private Sub UpdateDistrict()      Dim myArray()     Dim myElement As Variant     cboDistrict.Clear          myArray = Array()          If cboStations.Text = "Annual" Then       If cboYear.Text = "2010" Or cboYear.Text = "2011" Or cboYear.Text = "2012" Then          myArray = Array("Abilene", "Amarillo", "Atlanta", "Austin", "Beaumont", "Brownwood", "Bryan", "Childress", "Corpus_Christi", "Dallas", "El_Paso", "Fort_Worth", "Houston", "Laredo", "Lubbock", "Lufkin", "Odessa", "Paris", "Pharr", "San Angelo", "San_Antonio", "Tyler", "Waco", "Wichita_Falls", "Yoakum") '      ElseIf cboYear.Text = "2011" Then '         myArray = Array("Abilene", "Amarillo", "Atlanta", "Austin", "Beaumont", "Brownwood", "Bryan", "Childress", "Corpus_Christi", "Dallas", "El_Paso", "Fort_Worth", "Houston", "Laredo", "Lubbock", "Lufkin", "Odessa", "Paris", "Pharr", "San Angelo", "San_Antonio", "Tyler", "Waco", "Wichita_Falls", "Yoakum") '      ElseIf cboYear.Text = "2012" Then '          myArray = Array("Abilene", "Amarillo", "Atlanta", "Austin", "Beaumont", "Brownwood", "Bryan", "Childress", "Corpus_Christi", "Dallas", "El_Paso", "Fort_Worth", "Houston", "Laredo", "Lubbock", "Lufkin", "Odessa", "Paris", "Pharr", "San Angelo", "San_Antonio", "Tyler", "Waco", "Wichita_Falls", "Yoakum") '      ElseIf cboYear.Text = "2012" Then '           myArray = Array("Abilene", "Amarillo", "Atlanta", "Austin", "Beaumont", "Brownwood", "Bryan", "Childress", "Corpus_Christi", "Dallas", "El_Paso", "Fort_Worth", "Houston", "Laredo", "Lubbock", "Lufkin", "Odessa", "Paris", "Pharr", "San Angelo", "San_Antonio", "Tyler", "Waco", "Wichita_Falls", "Yoakum") '      ElseIf cboYear.Text = "2013" Then '           myArray = Array() '      ElseIf cboYear.Text = "2014" Then '           myArray = Array()       End If          ElseIf cboStations.Text = "Urban" Then         If cboYear.Text = "2010" Then             myArray = Array("Abilene", "Amarillo", "Austin", "San_Antonio", "Waco", "Wichita_Falls")         ElseIf cboYear.Text = "2011" Then             myArray = Array("Beaumont", "Houston")         ElseIf cboYear.Text = "2012" Then 'or just Else             myArray = Array("Brownwood", "Bryan", "Childress", "Corpus_Christi", "El_Paso", "Lubbock", "Odessa", "Yoakum") '        ElseIf cboYear.Text = "2013" Then '            myArray = Array() '        ElseIf cboYear.Text = "2014" Then '            myArray = Array()         End If     End If          For Each myElement In myArray         cboDistrict.AddItem myElement     Next  End Sub
KenBuja
Based on your question over on GIS.StackExchange and some of your previous questions, you could do something like this
    dim myArray() as String
    cboDistrict.Clear
           myArray = Array ("Abilene", "Amarillo", "Austin", "San_Antonio", "Waco", "Wichita_Falls" )
        Elseif cboYear.Text = "2011" Then
           myArray = Array ("Beaumont", "Houston")
        Elseif cboYear.Text = "2012" Then 'or just Else
            myArray = Array ("Brownwood", "Bryan", "Childress", "Corpus_Christi", "El_Paso", Lubbock, "Odessa", "Yoakum")
        End If
    Elseif cboStations.Text = "Rural"
           myArray = Array ("Abilene", "Waco", "Wichita_Falls" )
           myArray = Array ("Beaumont")
            myArray = Array ("Brownwood", Lubbock, "Odessa", "Yoakum")
        End If
    End If
    For Each myElement in myArray
End Sub
MichelleCouden1
OK, Ken before I write in you code and delete mine. I have a question about my code. Why would the district combobox not be clearing in this section?
         cboYear.Clear
      cboYear.AddItem "2010"
      cboYear.AddItem "2011"
      cboYear.AddItem "2012"
        ElseIf cboYear.Text = "2010" Then
           cboDistrict.Clear
        cboDistrict.AddItem "Abilene"
        cboDistrict.AddItem "Amarillo"
        cboDistrict.AddItem "Austin"
        cboDistrict.AddItem "San_Antonio"
        cboDistrict.AddItem "Waco"
        cboDistrict.AddItem "Wichita_Falls"
              cboDistrict.Clear
           cboDistrict.AddItem "Beaumont"
           cboDistrict.AddItem "Houston"
                cboDistrict.Clear
             cboDistrict.AddItem "Brownwood"
             cboDistrict.AddItem "Bryan"
             cboDistrict.AddItem "Childress"
             cboDistrict.AddItem "Corpus_Christi"
             cboDistrict.AddItem "El_Paso"
             cboDistrict.AddItem "Lubbock"
             cboDistrict.AddItem "Odessa"
             cboDistrict.AddItem "Yoakum"
       End If
KenBuja
The easiest thing would be to move cboDistrict.Clear out of the loop altogether.
However, your syntax is incorrect for the decisions. The If loop will first evaluate what is selected in the cboStations control. If that is "Urban" it will add in the years then exit from the loop. It will never try to evaluate what has been selected in the cboYear control (and you don't have the line cboDistrict.Clear in that first evaluation).
You mistakenly put a / in the first CODE block. If you remove that, it will make it easier to read.
MichelleCouden1
OK, one more question. Where do I put the code? In cboStations_Change() or cboYear_Change().
KenBuja
This code would go into the cboYear_Change sub. In the cboStations_Change sub, I would image you'd have this code
cboYear.Clear
Elseif cboStations.Text = "Rural" Then
End If
MichelleCouden1
OK, I am getting a type mismatch???? I will attach my whole code. See Attached. It's the way I have the Annual statement worded.
KenBuja
What line are you getting this on?
Also it looks like you want to combine the two If statements. If you are using both arrays to populate cboDistrict (you left off that code) then only use one array.
   myArray = Array("Abilene", ...
Else If cboStations.Text = "Urban" Then  ' or just Else If if you won't have additional stations
      etc
End If
MichelleCouden1
I'm sorry Ken, I thought I included that. I'm getting this error on the Stations.Text = "Annual" etc....
Is there maybe a chance I can get the other loop to work? Because everything fills in correctly but the urban district names. It would be easier to fix. OR is it just better to change it all out.
