Texture random and depending on
2705
04-04-2013 01:18 AM
MichaelPrede
Hi all!
I have simple boxes and some textures:
I would like to texturize the boxes with following rule:
left and right side have the same random texture
than:
front and back side texture with the same id like left and right:
In my following test rule left and right side have random but different textures AND I've no idea how to select the front/back texture depending on left/right texture.
Thanks a lot for help!
michael
[PHP]/**
* File:    test2.cga
* Created:
* Author:
version "2012.1"
leftrighttex = fileRandom("assets/facades/textures/leftrighttex*.jpg")
frontbacktex = fileRandom("assets/facades/textures/frontbacktex*.jpg")
Lot -->
extrude(world.y, 10)
comp(f) { 0 : NIL | left : Leftright | right : Leftright | front : Frontback | back : Frontback}
Leftright -->
setupProjection(0, scope.xy, '1, '1)
texture(leftrighttex)
projectUV(0)
comp(f) { front : Frontback | back : Frontback}
Frontback -->
texture(frontbacktex)
projectUV(0)
[/PHP]
MatthiasBuehler1
Hi ..
try this :
I did not check the code, may contain an error, but gives you the idea :
 texPath = "assets/myTextures/" const textureIndex = rint(rand(1, 3))   @StartRule Lot -->     alignScopeToAxes(y)     s(1,1,1)     center(xz)     i("builtin:cube")     comp(f) {front : Face("front") | back : Face("back") | all: Face("other") }  Face ( sideSelector ) -->     case sideSelector == "front" || sideSelector == "back" :         setupProjection(0, scope.xy, '1, '1)         projectUV(0)         texture ( texPath + "frontback" + textureIndex + ".jpg" )     else :         DoSomethingElse.
Note that the actually used texture path is concatenated by different elements you're interested in.
Using a 'const' makes sure that you have a constant number value throughout the whole model.
Does this help ?
MatthiasBuehler1
Hi ..
try this :
Does this help ?
MichaelPrede
error correction... wow it works!
Thanks a lot!
michael
MatthiasBuehler1
I've fixed the bracket errors above.
