Renaming multiple Featureclasses
11630
9
03-29-2013 10:42 AM
RodC
I need to create a python script that would rename all the feature classes within multiple featuredatasets in a gdb (the gdb is in ArcSDE if that makes any difference). The feature classes are in a set format and I need to change the prefix and part of the suffix.
For example:
from "road_1234567ns" to "RD_1234567_NS12_13"
where 1234567 is the string that I need to keep (and is unique to each feature class) and prefix of "Road" is a constant that I need to replace with "RD_". Suffix is constant as well, "ns" replaced with "_NS12_13"
The renamed classes will be separated by an underscore
I am just starting out with python and eager to learn more, if anyone has any helpful insights, that would be greatly appreciated. I am using ArcGIS 10.1
Thank you!
JakeSkinner
Esri Esteemed Contributor
You could do something like below:
lstDatasets = arcpy.ListDatasets("*") for dataset in lstDatasets:     lstFCs = arcpy.ListFeatureClasses("road_*", "", dataset)     for fc in lstFCs:         if "NS" in fc:              oldName = str(fc)              newName = oldName.replace("road", "RD")              newName = newName.replace("NS", "_NS12_13")              arcpy.Rename_management(fc, newName)
JakeSkinner
Hi Rodrigo,
Here is an example:
import arcpy
from arcpy import env
env.workspace = r"C:\temp\python\test.gdb"
    for fc in lstFCs:
        oldName = str(fc)
        newName = newName.replace("ns", "_NS12_13")
danashney
When I run this it only replaces the text for the last "newName" line, so in your example it would only replace the "ns" with "_NS12_13" and ignore the line that replaces "road". Any idea why that might be?
MDB_GIS
I know this is many years after the initial post, but holy cow, thank you so much for this. Using this, I was able to automate renaming 500+ feature classes.
RodC
Hi Jake,
this worked great, thanks!
I also wanted to see if the just "ns" portion could also search featureclasses that are written in capital letters such as "NS"?
Is there a way to make this case- insensitive?
thanks again!
JakeSkinner
RodC
Hi Jake,
thanks again!
Disregard this question.
I got it to work! just added another newName line
thanks!
ChrisGraves1
Hey Guys,
Thanks for the information. I'm looking to do the opposite where I would like to create a suffix on many different feature class names like '_1405' for example.
Chris
DarrenWiens2
Chris, you would concatenate the original featureclass name with the new suffix.
newName = str(fc) + '_1045'
AREGIS
Any help on how to replace the last 3 characters across multiple feature class names?
