Merge multiple RasterDataset
4019
17
03-28-2013 02:32 AM
oyleiste
Hello
I can get Linear Line of Sight from a single DTED file; which had beed opened by:
IWorkspaceFactory wsf = new RasterWorkspaceFactoryClass(); IRasterWorkspace rasterWS = (IRasterWorkspace)wsf.OpenFromFile(foldername, 0); IRasterDataset rasterDS = rasterWS.OpenRasterDataset("n42.dt0"); //DTED Level 0 file
Single DTED file means that both observer and target are in the DTED file's area.
Well, the problem occurs when I load more than one DTED files and want to use these functions:
IRaster raster = rasterDS.CreateDefaultRaster(); RasterSurfaceClass rsc = new RasterSurfaceClass(); rsc.PutRaster(raster); [INDENT]rsc.GetElevation(point);[/INDENT] [INDENT]rsc.GetLineOfSight(blah, blah, blah);
[/INDENT]
If observer is in a DTED file and target is in another DTED file, GetLineOfSight function fails obviously.
How can I merge two RasterDataset to give rsc.PutRaster() function one single raster?
Or
How can I put more than one raster in RasterSurfaceClass?
Thank you
Sincerely
oyleiste
Well, after a lot of struggling with this stuff, I solved the problem :cool: I'll share the code and explain it, so people can use it easily.
If you want to merge/mosaic some IRasterDataset, you can use my code:
IRasterCollection rc = (IRasterCollection) new MosaicRasterClass();
#region Add some IRasterDataset to the rc (IRasterCollection)
rc.Insert(0, rasterDataset0);
rc.Insert(1, rasterDataset1);
rc.Insert(2, rasterDataset2);
rc.Insert(3, rasterDataset3);
#endregion
ISaveAs2 save = (ISaveAs2) rc;
IRasterStorageDef st = new RasterStorageDefClass();
IRasterStorageDef3 store = (IRasterStorageDef3)st;
store.CompressionType = esriRasterCompressionType.esriRasterCompressionUncompressed;
store.Tiled = false;
IRasterDataset resultDataset = save.SaveAsRasterDataset("ResultDTED.dt0", _workspace_, "DEM", store);
First, you should create a IRasterCollection and add some IRasterDataset into it. Then you should create ISaveAs2 and cast rc to it. Then create IRasterStorageDef stuff. Finally, use ISaveAs2's SaveAsRasterDataset function to save merged/mosaicked RasterDataset to file and use it's return value as IRasterDataset. resultDataset contains the merged dataset.
Thank everyone for replying, specially Jason.
Sincerely
JasonPike
Hello
[/INDENT]
Or
Thank you
Sincerely
I think you are looking for a mosaic: http://resources.arcgis.com/en/help/main/10.1/index.html#//009t000000n6000000
You can find a code example here: http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/d/0001000002z0000000.ht...
Maximum seems like it would be appropriate for what you're doing:
"The Maximum method determines the higher pixel value from the two raster datasets that are overlapping."
http://resources.arcgis.com/en/help/main/10.1/index.html#/Mosaic_operators/009t000000n8000000/
oyleiste
Thank you Jason for your guide.
I think I should use mosaic but I tried a lot and couldn't use IRasterDataset which contains DTED Level 0; for mosaic.
The example code is so confusing also.
I think you can't use IRasterDataset for mosaic. Right?
oyleiste
After a lot of googling, I found out that I should create a IRasterDatasetEdit3, copy first DTED's IRasterDataset to it and then, append other DTEDs using IRasterDatasetEdit3.Mosaic function. Here is my code's screenshot:
[ATTACH=CONFIG]23074[/ATTACH]
Unfortunately Mosaic(IRaster raster, double tolerance) function fails at run-time execution. I have no idea why. Does anyone has idea?
By the way, that's tolerance (second parameter) in Mosaic?!
Please guide me to this 😞
Thank you
Sincerely
JasonPike
Thank you
Sincerely
You did a great job annotating the screen capture! Can you put a try-catch block around the code that fails and dump the contents of the exception to a message box (or console)?
try
    // code that is failing
catch( Exception e)
    MessageBox.Show( e.ToString());
JasonPike
Thank you
Sincerely
I don't know if there is any code above what you pasted in the screenshot, but from what I can see it appears that you didn't create the default raster for the first raster in the array. Maybe you can try the following:
IRasterDatasetEdit3 rasterDSE = (IRasterDatasetEdit3)rasterDS[0].CreateDefaultRaster();
for(int i = 1; i < rasterDS.Count; i++ )
 rasterDSE.Mosaic((IRaster)rasterDS.CreateDefaultRaster(), 1000);
Also, I noticed that you're creating the default raster twice in the loop. While I doubt this is causing an exception, it is probably expensive and consuming a good bit of memory. Looking at the API, it doesn't seem like you would need the cast to IRaster either, but I haven't tried it.
Try one of the following solutions:
#1 - Reuse output of first call
IRaster r = rasterDS.CreateDefaultRaster();
rasterDSE.Mosaic(r, 1000);
#2 - Don't make first call
rasterDSE.Mosaic(rasterDS.CreateDefaultRaster(), 1000);
I prefer #1 because it allows the opportunity to release the raster once you've added it to the mosaic:
IRaster r = null;
try
finally
    if( r != null )
     Marshal.ReleaseComObject( r );
oyleiste
Actually, the first CreateDefaultRaster was mistake (I put it there for my own debugging).
Now, my code is like this:
[ATTACH=CONFIG]23082[/ATTACH]
But, still the same problem. Fails at Mosaic function. I have no idea about it's second paramter. I just give random numbers 😐
Why there isn't any explanation or sample about this function?!
ArcGIS bored me a lot 😞
Thank you for your reply; Jason
Sincerely
JasonPike
Sincerely
Ah! CreateDefaultRaster() returns a raster, not a raster dataset!
You need a raster dataset to create the mosaic:
http://edndoc.esri.com/arcobjects/9.2/NET/dd494eb7-b56b-4e7a-adeb-0eccc1f9765c.htm
Once you create the raster dataset, you can cast it to IRasterDatasetEdit and use the mosaic function to add your rasters (created using the CreateDefaultRaster() method.
Make sense?
JasonPike
Make sense?
I now realize that is what you've been trying to do--I need more coffee.
How are you creating the raster datasets in your array?
The documentation is a little light on details. I'd like to know what the tolerance does--simply knowing that "tolerance is a parameter of type double" tells us nothing. Bah!
This tells you a little bit about the raster datasets. I would do some research into the terminology. I would ask questions about whether the cell sizes have to the same between rasters your merging, etc.
oyleiste
Yes, CreateDefaultRaster returns IRaster; not IRasterDataset. But keep in mind that IRasterDatasetEdit.Mosaic gets IRaster as first parameter, not IRasterDataset. That's why I use rasterDS[0].CreateDefaultRaster() function; to get IRaster and pass it to Mosaic function.
The link; creates a IRasterDataset for a image (map). Because it copies pixels into it. My IRastarDataset's format is "DTED Level 0", not map nor image. So, I think I can't use it.
I need more tea 😄
I get IRasterDataset like this:
List<IRasterDataset> rasterDS = new List<IRasterDataset>();
rasterDS.Add(rasterWS.OpenRasterDataset(DTED_filename)); //"n34.dt0" for ex.
Yes, the documentation just says it's datatype: double 😐
