File GDB feature class editing problem
863
03-22-2013 04:36 AM
DainiusTamosiunas
I'm trying to add new feature to file GDB feature class and keep getting this error: Objects in this class cannot be updated outside an edit session. Feature class has attachments enabled (exists relationships). Googled alot about this problem and still can't figure it out. FYI I'm developing a standalone application. Any thougts? My code:
[PHP]
Public Shared Sub CreateFeature(ByVal workspace As IWorkspace, ByVal featureClass As IFeatureClass, ByVal point As ArcGIS.Geometry.IPoint, ByVal data As String)
        Dim workspaceEdit As IWorkspaceEdit = CType(workspace, IWorkspaceEdit)
        workspaceEdit.StartEditing(True)
        workspaceEdit.StartEditOperation()
        Dim featureBuffer As IFeatureBuffer = featureClass.CreateFeatureBuffer()
        Dim featureCursor As IFeatureCursor = featureClass.Insert(True)
        Dim featureOID As Object
        featureBuffer.Value(featureBuffer.Fields.FindField("Data")) = data
        featureBuffer.Shape = point
        featureOID = featureCursor.InsertFeature(featureBuffer)
        featureCursor.Flush()
        workspaceEdit.StopEditOperation()
        workspaceEdit.StopEditing(True)
    End Sub
[/PHP]
Thanks in advance 🙂
DainiusTamosiunas
Figured it out. It was a license binding issue.
I was using:
ESRI.ArcGIS.RuntimeManager.BindLicense(ProductCode.Desktop)
instead of:
ESRI.ArcGIS.RuntimeManager.BindLicense(ProductCode.Desktop, LicenseLevel.GeodatabaseUpdate)
DainiusTamosiunas
Still haven't figured it out.. 🙂 Forgot to mention that error occurs after this statement:
[PHP]
[/PHP]
DainiusTamosiunas
I was using:
instead of:
