SearchCursor where clause
1755
5
03-19-2013 08:51 AM
TonyAlmeida
MVP Regular Contributor
I a script that selections by location, but after that i need it to search the selected in the "Year" field anything >= to 2009, then copy those features out. Any help would be very appreciated.
Her is what i currently have but i am getting an error of nameerror: name 'rows is not defined.
arcpy.SelectLayerByLocation_management(CCP, "WITHIN_A_DISTANCE", SP2, "1 MILE", "NEW_SELECTION")
if int(arcpy.GetCount_management("CURRENT_CUPS").getOutput(0)) > 0:
    rows.arcpy.SearchCursor(CCP, "YEAR >=2009", "", "YEAR", "YEAR A")
    for row in rows:
        arcpy.CopyFeatures_management("CURRENT_CUPS", "CUPS")
Thanks.
MathewCoyle
Honored Contributor
You can just use feature class to feature class with an expression.
arcpy.SelectLayerByLocation_management(CCP, "WITHIN_A_DISTANCE", SP2, "1 MILE", "NEW_SELECTION") if int(arcpy.GetCount_management(CCP).getOutput(0)) > 0:     expression = "YEAR >=2009"     arcpy.FeatureClassToFeatureClass_conversion(CCP, out_workspace, "CUPS", expression)
MathewCoyle
Honored Contributor
Are you wanting to copy every feature selected as its own feature class?
TonyAlmeida
No just into one, into "CUPS".
MathewCoyle
Honored Contributor
Then you don't need to bother with a cursor at all.
    arcpy.CopyFeatures_management(CCP, "CUPS")
TonyAlmeida
my previous code was before;
i need to selected layer by location  which is i did here
but then i need to select from that selection all the features that are 2009 and up from the "Years" field.
Thanks.
MathewCoyle
Honored Contributor
