Error on using an SOE project Template
1567
03-12-2013 11:02 AM
BrentHoskisson
In visual studio I create a project and use the REST Template.
Without doing anything else, I build the project and get
Could not load file or assembly 'ESRI.ArcGIS.SOESupport, Version=10.1.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86' or one of its dependencies. The system cannot find the file specified.
I verified that the file in the references exists on the computer.  It is, however, version 10.1.0.3035 - as are the rest of the referenced ESRI assemblies in the project which also exist.  I suppose that means the problem must be "one of its dependencies".  How do I figure out what the dependencies are?
UPDATE: It has something to do with this line in the csproj file:
<Import Project="$(MSBuildExtensionsPath)\ESRI\ESRI.ArcGIS.AddIns.Server.targets" Condition="Exists('$(MSBuildExtensionsPath)\ESRI\ESRI.ArcGIS.AddIns.Server.targets')" />
When I comment it out, it builds properly.
RichardWatson
BrentHoskisson
That document was not in my search lists when I looked for it. It's too bad ESRI can't link to these things in the help documents.
Thanks.
