map scalebar in ios api
4439
03-04-2013 04:31 PM
HumzaAkhtar
Hi all,
I could not find any map scale bar in the reference of iOS api? Does 10.1.1 sdk doesnot have this capability to add a scale bar unlike SDK for WPF or SDK for java script?
NimeshJarecha
No, SDK does not provide scale bar. You'll have to write your own.
Regards,
Nimesh
AkhilChoran_Balan
Just wondering if this is still not available. Anyone has any solution on how to do this?
ShiminCai
Hi Akhil,
I was also looking for a scalebar solution in the forum but couldn't find any. So I did a very simple scalebar (see the attached image).
The idea is to use a fixed-width image view to show a scalebar image. Then calculate the width of the image view in map unit which is map scale dependent. In another word the width of the image view represents different map distances at different map scales.
override func viewDidLoad()
        super.viewDidLoad()
        // Do any additional setup after loading the view, typically from a nib.
        // set up and load your map here
        //Register map pan and zoom notifications for scale bar
        NSNotificationCenter.defaultCenter().addObserver(self, selector: "mapViewDidEndPanningZooming", name: AGSMapViewDidEndZoomingNotification, object: nil)
        NSNotificationCenter.defaultCenter().addObserver(self, selector: "mapViewDidEndPanningZooming", name: AGSMapViewDidEndPanningNotification, object: nil)
         // the reason to register the AGSMapViewDidEndPanningNotification is to account for the device rotations.
func mapViewDidEndPanningZooming()
        //Scale
        var formatter = NSNumberFormatter()
        formatter.numberStyle = NSNumberFormatterStyle.DecimalStyle
        let groupingSeparator: String! = NSLocale.currentLocale().objectForKey(NSLocaleGroupingSeparator) as! String
        formatter.groupingSeparator = groupingSeparator
        formatter.groupingSize = 3
        formatter.alwaysShowsDecimalSeparator = false
        formatter.usesGroupingSeparator = true
        var scale: Double = round(self.mapView.mapScale)
        self.scaleLabel.text = "1 : " + formatter.stringFromNumber(NSNumber(double: scale))!
        //Scale bar
        let screenPointStart = CGPoint(x: self.scalebar.frame.origin.x, y: self.scalebar.frame.origin.y)
        let mapPointStart = self.mapView.toMapPoint(screenPointStart)
        let screenPointEnd = CGPoint(x: self.scalebar.frame.origin.x + self.scalebar.frame.size.width, y: self.scalebar.frame.origin.y)
        let mapPointEnd = self.mapView.toMapPoint(screenPointEnd)
        let ge = AGSGeometryEngine.defaultGeometryEngine()
        var distance = ge.distanceFromGeometry(mapPointStart, toGeometry: mapPointEnd)
        //the distance calculated here is in metres with the spatial reference GDA 1994 New South Wales Lambert
        if(distance > 10000) //10km
            //show the labels in km
            self.scalebarMiddleLabel.text = String(format:"%0.0f", distance/2000)
            self.scalebarEndLabel.text = String(format:"%0.0f km", distance/1000)
        else
            //show the labels in m
            self.scalebarMiddleLabel.text = String(format:"%0.0f", distance/2)
            self.scalebarEndLabel.text = String(format:"%0.0f m", distance)
Hope it helps.
Shimin
AkhilChoran_Balan
Thanks for the help Shimin. I will check with this.
