Xcode Storyboarding
3060
03-01-2013 03:37 PM
ShiminCai
Is it possible to write apps like OnlineOfflineEditingSample, FeatureLayerEditingSample, etc using Xcode storyboard? In these apps the buttons on the navigation item are dynamically loaded/changed. Do I have to dynamically create and attach a segue to those buttons to present relevant view controllers?  Is it possible to create those segues in advance in Xcode?
Shimin
ShiminCai
Hi Dana,
Thanks a lot for your explanations which have made a lot of senses to me.
Cheers,
Shimin
DanaMaher
Shimin
Yes, you can define segues that are attached to specific view controllers, but not a view element within the view controller, and then call the -(void)performSegue:withIdentifier: method of UIViewController. Thus, if you dynamically create and swap navigation items within a UIViewController, you can assign an action to each item that calls the appropriate segue.
Part 2 of this tutorial does a good job of explaining all the relevant details of segues in Storyboard.
Additionally, if you are building a complex project, learn to use multiple Storyboards in a single project. A single Storyboard works well, saves time, and makes your UI/UX clearer if you have a simple app that mostly pushes between Apple's default view classes and has a relatively linear progression. If you are building a more complicated app that has branched or non-linear workflow and incorporates custom view classes, a single Storyboard becomes a time suck and obfuscates your UI/UX flow.
ShiminCai
Hi Dana,
Cheers,
Shimin
