ESRI Base Map Projection Error in Web Ap Template
1145
02-27-2013 07:21 AM
BeckyHjelm
When switching from our local basemaps to the ESRI bm in the Basic Web AP template the projection has an error.
Please see this item and to any of the bm entitled "world .."
http://bit.ly/Wiin4I
KellyHutchins
Esri Notable Contributor
I ran a quick test using your app and do not see any errors. Perhaps you found and fixed the issue?
Kelly
IanBroad2
Kelly
I think he means if you change the basemap to, for example, World Streets, it puts the data in northern Algeria.
KellyHutchins
Ahh I see - should have noticed that I was just looking for errors in the debug console. The Basic Viewer uses the Basemap Gallery widget from the JSAPI to display the basemaps. One of the restrictions on the basemap's in the gallery is that they all need to share the same spatial reference. You can find more details here:
http://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/#basemapgallery
AaronAustin
We just had a big discussion at our department GIS meeting about this very thing. Why can't the mapping applications handle different projections? The web map handles it fine. Does ESRI have any plans to make their mapping applications function as well as the web map? Or are we basically just out of luck. We'd like our users to have the option to use either type of basemap. (Which by the way they could if they were to view it in the web map version.) We talked to the agency that is supplying the non-web mercator basemaps we are using and they fear they would have to duplicate 3 terabytes of data in order to supply us with web mercator versions of those same basemaps. It would really be great if the mapping applications could just handle it on the fly.
