Tableframe in VB.net?
838
02-25-2013 10:17 AM
JoeMcCollum
Ewan Middleton's solution in VBA seems to not work in VB.net.
http://forums.esri.com/Thread.asp?c=93&f=992&t=57798
It gets hung up on ITableFrame.
Is there an Imports statement I need to use?
KenBuja
MVP Esteemed Contributor
It is in the ESRI.ArcGIS.ArcMapUI assembly. Make sure you have that added to your project and you can either use
Import ESRI.ArcGIS.ArcMapUI
or
Dim pTableFrame As ESRI.ArcGIS.ArcMapUI.ITableFrame
JoeMcCollum
It appears I need ESRI.ArcMap.Editor and ESRI.ArcMap.EditorExt as well.
