Using Python to Export all MXD's in a Directory
10503
02-24-2013 02:49 AM
JamesHockey
I was just wondering if anyone knew how I could use Python to open and export all *.mxd documents in a directory (as a pdf). At the moment I can open specific *.mxd documents and export them. If I could have a code however that looks in a directory and could open all the files within it and export all the maps it would save me a lot of time.
CPoynter
Try using model builder and one of the iterate functions to list and iterate MXD files in a workspace / directory and export to PDF.
If you have subfolders have a look into the arcpy Walk function to do recursive searches for MXD files.
Regards,
Craig
JeffMoulds
ModelBuilder will work, but if you want to do it in Python, like your post says, all you need is something like this that loops through all MXDs in a folder, then exports them to PDF.
import arcpy, os
folderPath = r"C:\Project"
for filename in os.listdir(folderPath):
    fullpath = os.path.join(folderPath, filename)
    if os.path.isfile(fullpath):
        basename, extension = os.path.splitext(fullpath)
        if extension.lower() == ".mxd":
            mxd = arcpy.mapping.MapDocument(fullpath)
            arcpy.mapping.ExportToPDF(mxd, basename + '.pdf')
SeanConlon
Jeff,  this works almost perfectly. In testing, it created PDF's out all my MXD's in a folder,  but is it possible to output to a different folder?  I tried messing around with your code but I don't have enough knowledge to get it to work.
thanks
Sean
CPoynter
Hi Sean,
Try something like:
import arcpy, os
outFolder = r"C:\Project\PDFs" ## create an output folder
arcpy.mapping.ExportToPDF(mxd, outFolder + basename + '.pdf')
You will probably need to create ‘PDFs’ folder before running script.
Regards,
Craig
C. Poynter
Information Technology Officer (Spatial Analysis) | Research Office, Spatial Data Analysis Network (SPAN)
Charles Sturt University
Boorooma Street
Wagga Wagga, NSW, 2678
Australia
Phone: +61 2 69332165
Fax: +61 2 69332735
Email: cpoynter@csu.edu.au<mailto:cpoynter@csu.edu.au>
www.csu.edu.au<http://www.csu.edu.au/>
