Help with Script Tool for Creating PDFs from MXDs
1572
10
02-22-2013 11:19 AM
MichelleCouden1
I need a little help. I have made a script tool to use to export my mxds into a pdf. It would be a single mxd into a single pdf. I am getting an error that the mxd path is incorrect. I have included my script below. Any help would be great!
# Necessary modules
import arcpy, os, string, sys
# For less complicated scripts -
# these 2 imports are necessary to utilize a simpler method of debugging outher than traceback
import win32ui, win32con
# example debug message to screen ......
# arcpy.AddMessage("mxd_file = " + str(mxd_file))
# val = win32ui.MessageBox("mxd_file = " + str(mxd_file), "title",
                          #win32con.MB_OKCANCEL)
#Paramaters...
mxdList = string.split(arcpy.GetParameterAsText(0), ";")
dir = arcpy.GetParameterAsText(1)
#Loop thru & take the base name of each MXD selected and append all map pages to a single pdf
# and save to chosen directory......
for mxdPath in mxdList:
mxd = arcpy.mapping.MapDocument(mxdPath)
name = mxdPath[:-4] + ".pdf"
file = dir + os.sep + os.path.basename(name)
ddp = mxd
ddp.exportToPDF(file, "ALL")
del mxd, file
MichelleCouden1
Thank You so much Jeff! It works great!
ChristiNelson1
not much help, but doesn't a list need to be surrounded by brackets?
MathewCoyle
Honored Contributor
What specifically is the error you are getting? Have you tried printing out the values of mxdPath and mxdList to see if they are indeed what you want? You can give this a try.
    arcpy.AddMessage(mxdPath)
    if os.path.exists(mxdPath):
        #name = mxdPath[:-4] + ".pdf"
        name = mxdPath.replace('.mxd', '.pdf', -1)
        ddp = mxd
Also remember to use
 tags when posting code to retain indentation.
MichelleCouden1
Does your script create a script tool to input several mxds to export as several PDFs. One PDF for each mxd. Or actually, I guess it would be easier to do one mxd at a time right!!
MathewCoyle
Honored Contributor
It should be able to handle a list of mxd paths to process on. As long as they all have DDP enabled.
MichelleCouden1
Is it alright to add data driven pages when all I have is one page\layout\dataframe per mxd? Meaning, I only have one page not multiple pages per mxd.
MathewCoyle
Honored Contributor
I'm afraid I don't follow. What are you using data driven pages for if not for multiple page exports? Could you not just use the default ExportToPDF function in that case?
MichelleCouden1
I'll try to explain better. Sorry! I am trying to make a script tool that will make my job a little faster. Here: I have 25 mxds (all have single pages) and I want the script tool to export all those mxds into a PDF for each mxd. For Example: Abilene.mxd into Abilene.pdf and Austin.mxd into Austin.pdf on and on ... I hope this explains where I'm going.
MathewCoyle
Honored Contributor
Is there some particular functionality of DDP you need? Are you getting any errors with the new code you were running?
JeffMoulds
Judging from your comment:
...you may not even need data driven pages. Here is a simple export from a list of mxd names:
import arcpy, os
mxdList = ['C:/temp/Counties.mxd','C:/temp/Counties2.mxd']
    print mxdPath
    output = mxdPath.replace('.mxd', '.pdf', -1)
    print output
    arcpy.mapping.ExportToPDF(mxd, output)
print 'done'
Here is another sample, that exports all MXDs in a folder to PDF:
import arcpy, os
folderPath = r"C:\Temp\Forum"
for filename in os.listdir(folderPath):
    fullpath = os.path.join(folderPath, filename)
    if os.path.isfile(fullpath):
        basename, extension = os.path.splitext(fullpath)
        if extension.lower() == ".mxd":
            mxd = arcpy.mapping.MapDocument(fullpath)
            arcpy.mapping.ExportToPDF(mxd, basename + '.pdf')
And if you do indeed need to export Data Driven Pages, than this line from your script is wrong:
ddp = mxd
It needs to be:
ddp = mxd.dataDrivenPages
For more info on DDP export, see here.
In your case, putting in print statements for the input mxd and output pdf file path for debugging purposes would be a good idea to make sure you got that right.
