Getting Automation Error on GP call to Erase.
923
02-19-2013 11:15 AM
CraigGraham
Good Afternoon,
I am running across an issue with using the geoprocessor with Erase.  I have used this style (below) many times, and with commands that require much more complex arguments.  I can't see what I'm doing wrong.  Any help or suggestions appreciated.
    Set pGP = CreateObject("esriGeoprocessing.GpDispatch.1")     pGP.OverwriteOutput = 1     If fso.FolderExists("C:\Program Files\ArcGIS") Then         pGP.Toolbox = "C:\Program Files\ArcGIS\ArcToolbox\Toolboxes\Analysis Tools.tbx"     Else         pGP.Toolbox = "C:\Program Files(x86)\ArcGIS\ArcToolbox\Toolboxes\Analysis Tools.tbx"     End If MsgBox "subErase - (In, Erase, Out) = " & vbNewLine & sInputLayer & vbNewLine & sEraseLayer & vbNewLine & sOutputLayer     pGP.Erase_Analyses sInputLayer, sEraseLayer, sOutputLayer     Set pGP = Nothing
It is failing at the call to the command.  The msgbox shows that all three variables are set to valid paths.  I ran the command in the command line interface, and no problem.
I'm testing on Win7 64, ArcGIS 9.3.1, ArcINFO license.
Thanks in advance for any assistance.
Take care,
Craig
CraigGraham
(EDITED)
I've tried another method, and initially it didn't work, then I took a break, and saw a couple of silly mistakes...
Now this works fine:
    Dim fso As New FileSystemObject     Dim pGp As IGeoProcessor     Dim sInputLayer As String, sOutputLayer As String     Dim pResult As IGeoProcessorResult     Dim pParamArray As IVariantArray 833:     Set pParamArray = New esriSystem.VarArray 839:     Set pGp = New GeoProcessor 840:     pGp.OverwriteOutput = True 843:     If fso.FolderExists("C:\Program Files\ArcGIS") Then 844:         pGp.AddToolbox "C:\Program Files\ArcGIS\ArcToolbox\Toolboxes\Analysis Tools.tbx" 846:     Else 847:         pGp.AddToolbox "C:\Program Files(x86)\ArcGIS\ArcToolbox\Toolboxes\Analysis Tools.tbx" 849:     End If 850:     pGp.AddOutputsToMap = False 851:   pParamArray.Add sInputLayer 852:   pParamArray.Add sOutputLayer 853:   pParamArray.Add iBufferDistance 854:   pParamArray.Add "OUTSIDE_ONLY" 856:   Set pResult = pGp.Execute("Buffer", pParamArray, Nothing) 859:     Set pGp = Nothing   Exit Sub CustomErrorHandler: 862:     MsgBox "Error in subBuffer2:" & vbNewLine & "Line " & GetErrorLineNumberString(Erl) & vbNewLine & "Error Number: " & Err.Number & vbNewLine & "Error Source: " & Err.Source & vbNewLine & "Issue: " & Err.Description
Still it is strange that the older method (in first post) has worked fine with things like network analyst, spatial analyst, other standard operations (new Featureclass, clip....) without a problem, and they use the exact same setup, and sam version of ArcGIS....
Cheers,
Craig
CraigGraham
(EDITED)
Cheers,
Craig
