ADO.NET Entity Data Model
1324
02-17-2013 10:53 PM
Gregory_KevinMorales
i have tried using ADO.NET Entity Data Model in my ArcDesktop project using dockable windows.
but every time i start debugging im getting a error.
COMException was unhandled by user code
Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
Private Sub SetupDockableWindow()
        If m_dockableWindow Is Nothing Then
            Dim dockWindowManager As IDockableWindowManager
            dockWindowManager = CType(m_application, IDockableWindowManager)
            If Not dockWindowManager Is Nothing Then
                Dim windowID As UID = New UIDClass
                windowID.Value = regKey.GetValue("dwUID") 'DockableWindowGuid
                m_dockableWindow = dockWindowManager.GetDockableWindow(windowID) ' <-----on this line
            End If
        End If
End Sub
JamesCrandall
            End If
        End If
End Sub
Add a Try...Catch with some error checking.  Or at minimum, step through and determine the exact line it is failing on.
have tried adding try catch... still getting an error in this line...
but if i remove the ADO.NET Entity Data Model the error won't appear...
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#//0023000000nq000000
sorry but i don't see anything related to entity data model in that link... or i just don't know what you mean...
