Merge Script
2418
02-13-2013 07:02 PM
ChristopherClark1
Does this python script look correct for a merge?
# Import arcpy module import arcpy, sys, traceback arcpy.env.overwriteOutput = True from os import path as p   # Set Workspace arcpy.env.workspace = r"G:\ChrisGIS\PS_Steelhead\Archive"  # Set Variables. "out" will be our output variable. Inside the "Try" loop we search all workspaces # for the Feature Class we are interested in. This list of feature classes is set to listFCS  out = r"G:\ChrisGIS\PS_Steelhead\Scratch"  for ws in arcpy.Listworkspaces("*", "FileGDB"):  arcpy.env.workspace = ws  print '\n\Searching in %s\n\n' %ws  listFCS = arcpy.ListFeatureClasses("*_NWIFC_STHD")  # Now Merge all Feature Classes and export to the Output  arcpy.Merge_management(listFCS, os.path.join(out, "Merged_HUC8_STHD") print "Done"
MarcinGasior
It's not clear what you want to do.
I suppose you want to merge feature classes from many geodatabases. If so, you have to collect all feature classes names with full path in one list and use this list in Merge.
Here's how code can look like (remember to create geodatabase in your scratch folder first):
import arcpy, sys, os, traceback arcpy.env.overwriteOutput = 1  # Set Workspace arcpy.env.workspace = r"G:\ChrisGIS\PS_Steelhead\Archive"  # Set Variables. "out" will be our output variable. Inside the "Try" loop we search all workspaces # for the Feature Class we are interested in. This list of feature classes is set to listFCS  out = r"G:\ChrisGIS\PS_Steelhead\Scratch\Scratch.gdb"   # list for all feature classes from different GDBs to merge fcToMerge = []  for ws in arcpy.ListWorkspaces("*", "FileGDB"):     arcpy.env.workspace = ws     print '\n\Searching in %s\n\n' %ws     listFCS = arcpy.ListFeatureClasses("*_NWIFC_STHD")      # create a list with full pathes to feature classes     listFCsFullPath =[]     for fc in listFCS:         listFCsFullPath.append(os.path.join(ws, fc))      fcToMerge += listFCsFullPath  # Now Merge all Feature Classes and export to the Output arcpy.Merge_management(fcToMerge, os.path.join(out, "Merged_HUC8_STHD")) print "Done"
MarcinGasior
MelissaBennett
I modified the included script, but I'm receiving an error
Failed to execute. Parameters not valid.
Error 000735: Input Datasets: Value is required
Failed to execute(merge)
I'm trying to combine all the fc in each gdb, in the topo folder, into a single gdb.  Each gdb has a feature dataset "lts" that contains all the fc (in case it matters). I'm not sure why fcToMerge isn't a valid input. Any help would be appreciated- thanks.
IanMurray
Honored Contributor
I believe it would be because you are not going into each feature dataset and then listing feature classes.  The example given assumes your feature classes are directly in the gdb, not in a feature dataset in a gdb.
you would need to use arcpy.ListDatasets in there to fix
# Set Workspace
fcToMerge = []
    for fd in  arcpy.ListDatasets("*", "Feature")
        arcpy.env.workspace = fd
        print '\n\Searching in %s\n\n' %fd
        listFCsFullPath =[]
        for fc in listFCS:
Edit: I copied the old code from m.gasior and edited that one to work, so you will need to rework it from what I did for yours, but that should fix it.
