version 10.1.1 problem with AGSMapView?
1440
02-11-2013 07:56 AM
DinaLi
Hi, I installed version 10.1.1 and the MapViewDemo runs fine. I created a new project in XCode using the Storyboard. I added a MapView and set the class to AGSMapView.
I changed the URLs for both the dynamic and tiled layers to ArcGIS services (http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer and http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StateCityHighway_USA/MapSe...). I
When I run the project, my map appears for a second and then the MapViewDemo map appears out of nowhere and hides mine. How can I prevent this strange behavior? I don't know where the MapViewDemo map is coming from.
DiveshGoyal
Can you upload your project?
DinaLi
Hi, I turned off "Custom Location" in the simulator and now it works.
