Using Wildcard to extract values with Field Calculator?
4503
02-07-2013 09:51 AM
DanEckberg
I'm trying to extract a portion of an existing field in an attribute table to a new field using Field Calculator and have been running into some difficulties. It seems like there must be a way to do this, although with my limited VBS and Python experience I can't be certain. I'm working with 10.0 (sp. 2)
The exact problem is this:
The layer I'm working with has a very long field, [PopUp] (which was created when converting a KMZ file to a feature class) whose contents for each feature look something like this:
...<td>LAND USE CODE</td> <td>954</td>...
I want to extract just the Land Use Code from the [PopUp] field and populate a new field with it (either a numeric field or string, I don't care).
The Land Use Code changes based on the feature in question and the length of the string varies for each feature both before and after this segment which I want to extract (so I can't use a function which just grabs X number of characters from the left or right side).
Is this possible using the Field Calculator, with either Python or VBScript?
If so, I assume it would require some way to indicate a wildcard on either side of the Land Use Code, but I know it doesn't work the same as a simple SQL query/search.
Any help would be greatly appreciated.
Thanks in advance!
by Anonymous User
Not applicable
Are you familiar with cursors?  This can be done very easily with an update cursor:
fc = r'path\to\your\featureClass'
rows = arcpy.UpdateCursor(fc)
for row in rows:
    row.Land_Use = int(''.join([i for i in row.PopUp if i.isdigit()]))
    rows.updateRow(row)
Where 'Land_Use' is the new field you want to extract the values to (I had it set up as a short integer field, hence the int() value).  The fc variable is just the path pointing to your feature class.  This just runs a simple test to extract all values within the text string that are integers.
DanEckberg
Thanks, that worked and helped lead me to my ultimate solution, which was as follows (and conducted from the stand-alone Python Window, not Field Calculator):
import re
fc='file path'
rows=arcpy.UpdateCursor(fc)
for row in rows:
     row.FieldName = re.search('LAND USE CODE</td>\n<td>(\d*)<' , row.PopUp).group(1)
     rows.updateRow(row)
