Query by Geometry
2609
02-06-2013 07:52 AM
VIKRANTKRISHNA
I am setting up the query geometry as
AGSQuery = [AGSQuery query]; query.geometry = graphic.geometry; query.returnGeometry = TRUE; query.spatialRelationship = AGSGeometryRelationIntersection  [queryTask executeWithQuery:query];
If I draw a line, query is done by line envelop. Is it possible to query by exact shape?
DanaMaher
I think you are using the wrong typedef. AGSGeometryRelationIntersection is enumerated in the AGSGeometryParameters typedef. The spatialRelationship property of AGSQuery uses the AGSSpatialRelationship typepef. If AGSGeometryRelationIntersection and AGSSpatialRelationship are keyed to different integers, which is likely, you are not performing the query you think you are performing.
DanaMaher
VIKRANTKRISHNA
Yes, that was it. Thanks!!
