Invert method problem
1045
02-05-2013 03:10 PM
babakkasraei
Hi Experts
I try to write some codes to hide unselected features in my map. I have written some part of it. The first part of the codes must find selected features. This part works as follows.
 def button3Click(self, selection):         index = self.listbox.curselection()                        label = self.listbox.get(index)           # Local variables:         layer = label          # describe the feature layer to access the the selected set         desc = arcpy.Describe(layer)          # FIDSet will contain the selected features         selectedFids = desc.FIDSet                   # If there are selectedFids (a selection set), write them to a new feature         # class in the current workspace.         if len(selectedFids) > 0:
In the other part I need to invert to find those features which are unselected. The method that I write for it doesn't work.
                       queryList = selectedFids.replace(';', ',')
Would you help me with this method.
Best regards
Babak
MathewCoyle
Honored Contributor
Use SWITCH_SELECTION as the selection type parameter.
arcpy.SelectLayerByAttribute_management(layer, "SWITCH_SELECTION")
http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000071000000
MathewCoyle
Honored Contributor
babakkasraei
Thank you Mathew
Great help.
Best regards
Babak
