Redrawing rivers in proportion to their discharge?
668
01-18-2013 04:58 PM
ElizabethWalsh
If there is another part of the forum where this would be more appropriate, please let me know.
Using the hydrology toolset and a digital elevation map, I was able to draw the stream network of my thesis area.  I have it drawn as a raster, and as a polyline shapefile which I created from the raster.
In the field, I performed direct measurements of river discharge.  I would like to re-draw my stream network so that the width of each stream is proportional to the volume of water flowing through it.
I don't even know where to begin with this, so any suggestions would be appreciated.
Thank you!
Elizabeth
MarkBoucher
Occasional Contributor III
Here's a good article:
http://blogs.esri.com/esri/arcgis/2008/05/03/u-s-hydro-flow-lines/
Also related this tool in Spatial Analyst:  Spatial Analyst Tools.tbx\Hydrology\Stream Order
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z00000057000000.htm
Use the tool to create the stream order and then use Quantities/proportional symbology.
Good Luck!
PS - This results in a raster. You then have to convert the stream raster to a feature to get the polylines that have a grid code based on the stream order. Use proportional symbology based on the grid code.
