web application does not show the correct layers
1232
01-17-2013 04:21 AM
SPNIOrganization
I have an organization subscription and also an arcgis server.
I added a layer from my server to my online organization.
in explorer online - I changed the symbology (and updated the changes to the service) and the basemap and saved a web map to my content. then - I opend the web map in arcgis.com viewer and published a basic web application.
In the apliccation - the layer has the old symbology and is turning off and on in a strange way.
this is a link to the web map: http://deshe.maps.arcgis.com/home/webmap/viewer.html?webmap=312ba268d184482e934805e604bb5719
this a link to the web App: http://deshe.maps.arcgis.com/apps/OnePane/basicviewer/index.html?appid=4c54c54d62ee493e8bbaac3779db2...
(the map is in Hebrew)
Hope you can help me.
Thank you,
Dikla.
MikeMinami
Esri Notable Contributor
This is a bug.
If you add your services specifing the URL as shown, it should work:
http://mapateva.org.il/arcgis/rest/services/Preservation/InvasiveSP/FeatureServer/1
The issue is that case is being taken into consideration in the software. You need to change "featureserver" to "FeatureServer" in the URL when you add the layer to the web map. Then it should work right.
Mike
MikeMinami
This is a bug.
Mike
SPNIOrganization
Thank You Mike, the App is working great.
But there is another problem:
I want to see the Features in my Desktop. When I'm adding the feature server using Add data from ArcGIS online and also when I'm choosing "open in Desktop 10.1" only one of the two layers is coming.
what can I do in order to see both of the layers in my desktop without publishing them seperatly?
