Error with installing sdk 2.3.2
1326
01-16-2013 06:25 AM
francescodi_vito
Hi guys, I upgraded my xcode to version 4.5.2. and following all the steps to install the latest version of the SDK I have two errors.
As first when i install the sdk does not create the path: $(HOME)/Library/SDKs/ArcGIS/iOS/, but all element are in this path: $(HOME)/SDKs/ArcGIS; this is the first error
the second error
after adding the string: -all_load -ObjC -framework ArcGIS if I try to launch an empty project i have this error:
linker command failed with exit code 1(use -v to see invocation)
Why this error? first the upgrade of my xcode i don't have any error.
I removed the armv7s entry (if it exists) from the Valid Architectures, but the error it's the same.
Any help please
DiveshGoyal
Can you ensure you are installing the latest version of the SDK (v10.1.1)?
Previous versions of the SDK (v2.3.2 and earlier) used to install under $(HOME)/SDKs/ArcGIS
The new SDK installs under $(HOME)/SDKs/ArcGIS/iOS
francescodi_vito
Ok. I used the wrong sdk.
Now it's ok
