Sub and Function not defined??
891
01-14-2013 11:00 AM
MichelleCouden1
My code error is sub and function not defined, when the command Map button is pushed!! Trying to understand VBA, not to sure what that means. My code is below please help!!
Private Sub cmdMap_Click()
    Dim cboStations As String
    Dim cboDistrict As String
    Dim mapDocument As IMapDocument
    Set mapDocument = New mapDocument
    If mapDocument.IsPresent("K:\TASS\4_MAPPING_DATA_SUPPORT\Traffic_Mapping\District_Maps\2012\Abilene\Abilene_Base_Map.mxd") Then
    mapDocument.Open ("K:\TASS\4_MAPPING_DATA_SUPPORT\Traffic_Mapping\District_Maps\2012\Abilene\Abilene_Base_Map.mxd")
    ElIf
        MsgBox "District Does Not Exist"
    End If
MarcinDruzgala
    ElIf
    End If
Same question everywhere, are you some kind of gis-troll?
http://forums.arcgis.com/threads/75211-Code-seems-to-be-caught-in-Loop!!
http://forums.arcgis.com/threads/74858-VBA-Help-with-Subroutines-and-Functions
http://forums.arcgis.com/threads/74687-Path-to-folder-and-mxd - answered !!
http://forums.arcgis.com/threads/74760-Code-for-going-to-Folder-and-Drawing-an-mxd-from-that-Folder!... - answered!
http://forums.arcgis.com/threads/74781-Command-for-accessing-and-Opening-Folder-to-have-access-to-mx...
http://gis.stackexchange.com/questions/48038/help-with-loop-my-program-seems-to-be-stuck-in-loop - closed with good explanation why, maybe you should read it.
http://gis.stackexchange.com/questions/46634/how-to-define-subroutines-and-functions - again asnwered....
http://gis.stackexchange.com/questions/46888/setting-a-path-to-a-variable-to-be-able-to-open-a-new-m... - .....
http://gis.stackexchange.com/questions/46634/how-to-define-subroutines-and-functions - agaaaaaaaaaaaaaaaaaaaaain and again
It's propably like a basic question, but you are asking it in wrong way. Just read what people are writing in their posts under your threads, that would help you a lot.
Regards,
MDruzgala
LeoDonahue
Try googling for your error message?
Google + "sub or function not defined" = http://msdn.microsoft.com/en-us/library/s8y42ktc%28v=vs.80%29.aspx
