Need help translating from VB to Python.
1743
01-12-2013 02:02 PM
AlexFlanagan
I'm currently completing the spatial analyst training but unfortunately it was made for 9.3, while I'm using 10.1.
While using the raster calculator I'm having trouble translating this to python.
Example is:
SetNull([Ownership] <> 200 OR [Soil] == 901, 1)
DavidPetrey1
Try the following:
SetNull(("Ownership"<> 200) | ("Soil" == 901), 1)
The Vertical Bar represents OR now. And raster names are within quotation marks. And I always find putting logic in its own brackets helps as well.
David
simplyGIS. Making GIS simple.
www.simplygis.co.uk/GISTraining.html
If this post helped answer your query please mark as answered to let others know.
DavidPetrey1
Try the following:
David
curtvprice
  • the "not equal" operator in Python is "!="
  • The names in quotes are (technically) raster layer names.
Here's my shot at it:
SetNull(("Ownership" != 200) | ("Soil" == 901), 1)
Arc 10.1 help:
Comparing Map Algebra between ArcGIS 9.x and 10
Building Expressions in Raster Calculator
DavidPetrey1
Ah yes, the new symbol for doesn't equal is !=, though I find <> still works (or is this just a random thing of my installation?), which I usually end up typing out of habit.
David
curtvprice
Learned something, thank you.
[noparse][/noparse]his is an obsolete usage kept for backwards compatibility only. New code should always use !=.
Python docs: Built-in Types - Comparisons
