problem with dissolving a stream
1630
01-10-2013 10:36 AM
saadatumohammed
Hello
can any one help me with a python script to dissolve a stream using their stream order. when i use arcgis tool to dissolve the stream segment using their order,some of the higher order segments join together. example is like 2 segments of order 2 join together to form one segment of order 2.i normally use split tool to split.but i want to write a tool and i need to automate this procedure to continue with my work. thanks in advance
ChrisSnyder
Honored Contributor
Are you specifying "SINGLE_PART" for the dissolve?
For whatever reason, ESRI decided to make "MULTI_PART" the default, which causes a lot of issues I think.
saadatumohammed
Hello Chris
thanks a lot. there has been much much improvement. however few once still remains. especially, a node where two  different segment of the same order meet. result in one rather than two segments. any advice is welcomes
ChrisSnyder
Honored Contributor
Hmmm.... Try checking the "Unsplit lines (optional)" setting - via a Python script that would be "UNSPLIT_LINES"
