Problem with Intersect_analysis
4216
12
01-09-2013 09:21 AM
DuaneDubey
I have a script that is to geocode addresses from a database, intersect the results with three boundary files and do a tabletotable conversion on the results.  Below is the intersect statement I am using.
arcpy.Intersect_analysis([geocode_results, boundary1_shp, boundary2_shp, boundary3_shp], qResults, "ALL", "", "INPUT")
The statement is failing on qResults (e.g. creating the output of the intersect).  It seams that no matter what I put there (file path or variable name), the compiler is appending ".shp.shp" to the file name which causes an invalid file error.
ERROR 000210: Cannot create output \\mydrive\ArcGIS\Default.gdb\qResults.shp.shp
ERROR 000354: The name contains invalid characters
Failed to execute (Intersect).
Any help, would be greatly appreciated.
Dan
MathewCoyle
Honored Contributor
What is the value of your qResults variable? What version of ArcGIS are you using and service pack?
DuaneDubey
We are using ArcGIS 10 SP 4
What should the value of the output variable be?  I've tried to assign it a .shp file or to simply give it a name and let the compiler figure it out.  Neither have worked.  My understanding is that when the intersect is complete, the result set is saved to a file and I am defining what to call it so that I can use it later.  Is that correct?
MathewCoyle
Honored Contributor
Since you are outputting to a geodatabase, which I am assuming is your env.workspace, you should just give it a name. Nothing else should be required.
qResults = 'output_featureclass'
DuaneDubey
Thank you for the reply. I tried setting the value of the output to 'output_featureclass' and I got the same error.
ERROR 000210: Cannot create output \\MyDrive\ArcGIS\Default.gdb\output_featureclass.shp.shp
Here is the full code:
# Import arcpy module
import arcpy
from arcpy import env
try:
   env.workspace = "\\\\MyDrive\\ArcGIS\\Default.gdb"
   if arcpy.Exists(dbo_View1):
       arcpy.Delete_management(dbo_View1)
   if arcpy.Exists(dbo_GeocodeAddresses3):
       arcpy.Delete_management(dbo_GeocodeAddresses3)
   # Local variables:
   dbo_CDM_ARCCHANCERY = "Database Connections\\Chancery.odc\\dbo.CDM_ARCCHANCERY"
   NewAASD_Streets = "\\\\MyDrive\Transportation\\ArcGIS ver 10\\Locators\\NewAASD_Streets"
   elembound_shp = "\\\\MyDrive\Transportation\\ArcGIS ver 10\\Boundaries\\elembound.shp"
   highbound_shp = "\\\\MyDrive\Transportation\\ArcGIS ver 10\\Boundaries\\highbound.shp"
   middlebound_shp = "\\\\MyDrive\Transportation\\ArcGIS ver 10\\Boundaries\\middlebound.shp"
   arc__VERSION_dbo_DEFAULT_ = "Database Servers\\MyServer_ARC.gds\\arc (VERSION:dbo.DEFAULT)"
   dbo_View1 = "dbo_View1"
   dbo_GeocodeAddresses3 = "\\\\MyDrive\\ArcGIS\\Default.gdb\\dbo_GeocodeAddresses3.shp"
   dbo_GeocodeAddresses3_Inters = 'output_featureclass'
   # Process: Make Table View
   arcpy.MakeTableView_management(dbo_CDM_ARCCHANCERY, dbo_View1, "", "", "Id Id VISIBLE NONE;StudentId StudentId VISIBLE NONE;'Last Name' 'Last Name' VISIBLE NONE;'First Name' 'First Name' VISIBLE NONE;'Middle Name' 'Middle Name' VISIBLE NONE;School School VISIBLE NONE;'School #' 'School #' VISIBLE NONE;'Street Number' 'Street Number' VISIBLE NONE;'Street Direction' 'Street Direction' VISIBLE NONE;Street Street VISIBLE NONE;'Street Type' 'Street Type' VISIBLE NONE;Apt Apt VISIBLE NONE;City City VISIBLE NONE;State State VISIBLE NONE;ZIP ZIP VISIBLE NONE;'Full Address' 'Full Address' VISIBLE NONE;DOB DOB VISIBLE NONE;Gender Gender VISIBLE NONE;Grade Grade VISIBLE NONE;Ethnicity Ethnicity VISIBLE NONE;LunchStatus LunchStatus VISIBLE NONE;PrivateSchool PrivateSchool VISIBLE NONE")
   # Process: Geocode Addresses
   arcpy.GeocodeAddresses_geocoding(dbo_View1, NewAASD_Streets, "Street 'Full Address' VISIBLE NONE;ZIP ZIP VISIBLE NONE", dbo_GeocodeAddresses3, "STATIC")
   # Process: Intersect
   arcpy.Intersect_analysis([dbo_GeocodeAddresses3, elembound_shp, highbound_shp, middlebound_shp], dbo_GeocodeAddresses3_Inters, "ALL", "", "INPUT")
   # Process: Table to Table
   arcpy.TableToTable_conversion(#Removed because of length#)
   # Cleanup temporary tables
except Exception, e:
    #If an error occurred, print line number and error message
    import traceback, sys
    tb = sys.exc_info()[2]
    print "Line %i" % tb.tb_lineno
    print e.message
curtvprice
I think the root of your problems may be this line:
You can't have a shapefile inside a geodatabase; this may be messing up your parameter validation and adding .shp to the output feature class name.
Just a tip, try "raw" strings to make it easier to copy and paste paths into code.
arcpy.env.workspace = r"\\MyDrive\ArcGIS\Default.gdb"
DuaneDubey
I removed the .shp from the GeocodeAddresses3 variable and got the below error:
dbo_GeocodeAddresses3 = r"\\MyDrive\ArcGIS\Default.gdb\dbo_GeocodeAddresses3"
Line 39
Failed to execute. Parameters are not valid.
ERROR 000732: Input Features: Dataset \\MyDrive\ArcGIS\Default.gdb\dbo_GeocodeAddresses3 #;'\\MyDrive\Transportation\ArcGIS ver 10\Boundaries\elembound.shp' #;'\\MyDrive\Transportation\ArcGIS ver 10\Boundaries\highbound.shp' #;'\\MyDrive\Transportation\ArcGIS ver 10\Boundaries\middlebound.shp' # does not exist or is not supported
How should I be handling the output from the GeocodeAddresses process?
curtvprice
My advice is to do this process interactively and look at the results window.
"Copy As Python Snippet" is your friend!
DuaneDubey
I will try doing that however, we used the interface initially.  It worked once and failed when we tried to run it again as a job.
DuaneDubey
OK, now I am working on my model.
I'm using:
1.  Geocode addresses to connect to a SQL Server table and geocode against a locator file.
2. Intersect to combine the results of #1 with three boundary files.
3. Table to Table to output the results of #2 to SQL Server Express which is installed on the GIS Server.
Question is related to #3.  The OLE DB connection to SQL appears to be read only.  How can I create a connection to SQL Server Express that can be written to?  Is there a way to create an ADO connection?
Dan
