Get Attributes from select feature on map using arcobjects
5968
01-06-2013 02:21 AM
shreyesshiv
I want to get the attributes of the selected feature on mouse click from the map.
Please help me with a C# sample code
thanks
ThavitinaiduGulivindala
1. If you want to get all the selected features in Map then
// Reset to the first selected feature
ESRI.ArcGIS.Geodatabase.IEnumFeature enumFeature = (ESRI.ArcGIS.Geodatabase.IEnumFeature)map.FeatureSelection; // Explicit Cast  enumFeature.Reset();
ESRI.ArcGIS.Geodatabase.IFeature feature = enumFeature.Next();
  while (!(feature == null))
       //Do you job here//
2. If you want to get all the features selected in a Layer then make use of IFeatureSelection interface
DannyDong
However, IFeatureSelection doesn't work with IEnumFeature. What to do? I have to use ISelection instead. Are there any other ways?
FridjofSchmidt
If you start from a FeatureLayer, cast it to IFeatureSelection and get IFeatureSelection.SelectionSet. ISelectionSet.Search returns a search cursor that you can use to loop over all selected features in the layer.
