check for selected features
5535
6
01-03-2013 09:13 AM
MikeLouwrens
I trying to create an arcpy script that will run only if there are selected features in a layer, however I can't figure out how to get arcpy to test for selected features.
I've read posts about using GetCount, however this seems to only work if there is a difference in the number of selected features to the full feature count of the layer.  I want my script to run even if EVERY feature in the layer is selected (but ONLY if features are selected).
Is there a way I can do this?
Cheers,
Mike.
ChrisFox3
Layer Describe properties has an FIDSet property which returns a semicolon-delimited string of selected feature IDs. If the string is empty no features are selected:
desc = arcpy.Describe(lyr) if not desc.FIDSet  == '':    print 'Layer has a selection'
CarlSunderman
I would think that you could get an initial count and assign as say numRecords then run a selection and set another get count as selRecords. then check if the selected count is null
by Anonymous User
Not applicable
Cheers,
Mike.
Yes, there are many ways to do this, here is one:
result = int(arcpy.GetCount_management(Parcels).getOutput(0))
if result:
    # do something
else:
    print 'No selected features'
MikeLouwrens
if result:
    # do something
else:
This returns a true result even if I haven't selected anything.  This only returns a false result if I run a selection and nothing is selected...
Mike.
ChrisFox3
MikeLouwrens
this is what I have done - I ran a selection on objectid = 1000000000000 (a feature that should never exist...) then my getcount will return 0 if nothing else selected, or the number of selected features if other features are already selected.
arcpy.SelectLayerByAttribute_management(layer.name,"ADD_TO_SELECTION",'"OBJECTID" = 1000000000000')
featurecount = int(arcpy.GetCount_management(layer.name).getOutput(0))
if featurecount > 0:
    #Do Something
else:
    arcpy.SelectLayerByAttribute_management(layer.name, "CLEAR_SELECTION")
This seems to work 😄
Cheers,
Mike.
MikeLouwrens
oh! that works too.  thanks for that 🙂
Cheers,
Mike.
