Little SQL query help please
2351
12
12-19-2012 07:05 AM
JonPedder
I always seem to get hung up on these simple strings.
Here again I don???t quite get the syntax for use in SelectLayerByAttribute_management
If I use the following with a field named ???Name??? the query works just fine
iQuery = ' "Name" = \'Joe Blogs\' ' arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", iQuery)
However when I try to use a variable I can never seem to get the syntax right
iPerson = ???Joe Blogs??? iQuery = '"Name" = "' + aCenterMapOn + '"' arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", iQuery)
T__WayneWhitley
Honored Contributor
Okay, sorry for the delay - but see the below, what I did that works (employing the techniques already discussed above).
I used a gdb feature class that I added a 'blank' row to in order to introduce the null vals (so I know I should get results).  Comments in the code below (again, it's an IDLE session):
IDLE 2.6.5       >>> import arcpy >>> fc = r'C:\Documents and Settings\whitley-wayne\Desktop\stage.gdb\RightBankPoints'  # (make sure the fc exists) >>> if arcpy.Exists(fc):print 'true'   true  # (could have entered the qry here for MFL, but you wanted to demo SelectLayerByAtt, which I think requires a layer) # (...so created a lyr first to feed into SelectLayerByAtt, a step only for demo purposes...) >>> arcpy.MakeFeatureLayer_management(fc, 'lyr') <Result 'lyr'>  # (verifying there are features in the lyr): >>> arcpy.GetCount_management('lyr').getOutput(0) u'198'  # (setting up the field with the correct delimiters [double quotes]): >>> selFld = arcpy.AddFieldDelimiters(fc,'RiverCode')  # (just checking...) >>> print selFld "RiverCode"  # (setting up the qry string): >>> qry = "%s %s" % (selFld, 'is not Null')  # (looks fine, ready for launch...) >>> print qry "RiverCode" is not Null  # (commence launch, the execution we've been waiting for): >>> arcpy.SelectLayerByAttribute_management('lyr', 'NEW_SELECTION', qry) <Result 'lyr'>  # (checking the count -- I entered 1 null record, so the count should be at least 1 less than before): >>> arcpy.GetCount_management('lyr').getOutput(0) u'197' >>>
And it is.  Mission accomplished, hope that helps you.
AndrewChapkowski
You can try this:
# your code
print iQuery
# modified code
print "\"%s\" = '%s'" % ("Name", "Joe Blogs")
You can substitute the Name and Value with a variable to make this more dynamic.
I would also look at the AddFieldDelimiters() in arcpy to ensure every field is formatted correctly.
JonPedder
Sorry, you've totally lost me!
T__WayneWhitley
Honored Contributor
Here's an example, employing the AddFieldDelimiters method - and since using IDLE and an SDE-contained fc instead of a ready feature layer (the required input for SelectLayerByAttributes), I used a similar tool MakeFeatureLayer to demonstrate the use of query syntax, but I am not yet accustomed to var substitution, so I'd take a keen look at Andrew's example.  Here's my simpler one:
>>> arcpy.env.workspace = r'Database Connections\MCPA.sde'
>>> inFC = 'MCPA.DBO.PARCEL_PUBLIC'
>>> qryFieldName = arcpy.AddFieldDelimiters(inFC, 'RECHAR')
>>> print qryFieldName
"RECHAR"
>>> qry = qryFieldName + " = '" + aCenterMapOn + "'"
>>> print qry
"RECHAR" = '00166972-004500'
(syntax):
>>> # SelectLayerByAttribute_management (in_layer_or_view, {selection_type}, {where_clause})
>>> # MakeFeatureLayer_management (in_features, out_layer, {where_clause}, {workspace}, {field_info})
>>> arcpy.MakeFeatureLayer_management(inFC, 'lyr', qry)
<Result 'lyr'>
(getting the count to verify the selection took place):
u'1'
AndrewChapkowski
Which part are you lost on?
JonPedder
Thanks very much! Now I "get it" the arcpy.AddFieldDelimiters and the help from Wayne did the trick.
Thanks !!
T__WayneWhitley
Honored Contributor
Great, and just so we 'get it more' while on the effort, always a good thing -- as suggested by Andrew, the 'variable string substitution' (not sure what it's called, but it's a purely Pythonic technique you can borrow to help make your query syntax more manageable), here's what you get when you combine or build on the above:
>>> qry2 = "%s = '%s'" % (qryFieldName, aCenterMapOn)
>>> print qry2
So to offer explanation, if you strip of the double quotes in the above expression component, you get:
%s = '%s'
...then %s is the substitution in the order provided in the paren (after the 3rd unquoted %).
The field delimiters in this case are taken care of by AddFieldDelimiters and already stored in qryFieldName - that's a direct substitution (%s).
The second param required the single quotes as querying for text values requires ('%s').  Had we been querying for numeric, then that would be a direct substitution as well (%s).
Thanks to Andrew at ESRI.
JonPedder
Guys, I'm hung up on one more of these, jeeze!
querying a text field for fields that are not empty. My search string that works in the attribute table is
iField = arcpy.AddFieldDelimiters(fc, "Area_Name")
iQuery = iField+ " IS NOT NULL"
This doesn't want to work in arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", iQuery)
Killin' me !
T__WayneWhitley
Honored Contributor
Have you tried IS NULL and get anything?  Are errors being returned or is it just not working?  If IS NULL works you can execute select by attribute again with SWITCH_SELECTION.
JonPedder
I'm getting a syntax error when using arcpy.SelectLayerByAttribute_management but the actual query works perfectly when running from within an attribute table and using Select By Attribute..
Thanks Wayne
Jon
