Command Line ConfigureWebAdaptor.exe Throwing File Error
4326
5
12-14-2012 06:15 AM
AndrewBrown1
Due to issues regarding the other webadaptor config methods, I am trying to use the command line configuration method using the ConfigureWebAdaptor.exe tool located in your C:\Program Files (x86)\Common Files\ArcGIS\WebAdaptor\IIS\Tools\ folder. Usage instructions could be found here: http://resources.arcgis.com/en/help/main/10.1/index.html#//01540000041q000000
Anyhow, when using a command line window, I try to open ConfigureWebAdaptor.exe, but it immediately throws an error:
"The image file ConfigureWebAdaptor.exe is valid, but is for a machine type other than the current machine"
We're running Windows Server 2003 SP2, 32-bit. Is this program built for 64-bit machines? Help!
RichardWatson
Yes, server is 64 bit only.
RichardWatson
AndrewBrown1
Does it say anywhere in the requirements that the command line config file needs to be executed on 64-bit only machines?
The system requirements for the web adaptor include 32-bit machines:
"Windows Server 2003 Service Pack 2 Standard, Enterprise, and Datacenter 32-bit and 64-bit (EM64T)"
RichardWatson
Here is the proof:
C:\Program Files (x86)\Common Files\ArcGIS\WebAdaptor\IIS\Tools>dumpbin -headers ConfigureWebAdaptor.exe
Microsoft (R) COFF/PE Dumper Version 11.00.50727.1
Copyright (C) Microsoft Corporation.  All rights reserved.
Dump of file ConfigureWebAdaptor.exe
PE signature found
File Type: EXECUTABLE IMAGE
FILE HEADER VALUES
            8664 machine (x64)
AndrewBrown1
Great, this isn't helping. Since the config website is malfunctioning with our current website, and this command line feature is limited to 64-bit machines, we have no way of configuring the web adaptor on our 32-bit web machine!
Thanks, ESRI.
LiamO_Connor_Hannon
Hi Andrew,
Did you get a solution to this issue in the end. Would be interested to know as I have the same issue,
Liam
