Check each row geometry is inside a perimeter with Python - how?
1197
12-14-2012 12:01 AM
JamesMorrison1
Hello Everyone
Software version: 9.3.1 / python 2.5
Problem: I have a polygon feature class "FC1" with 1000 records and wish to find the ones laying outside of a given perimeter (in the form of 1 record in another feature class "PERI1").
I know about the gp.erase option but I wish to report to the user that OBJECTID x lies outside PERI1 - so I thought I could loop through FC1 and compare each row geometry withe the PERI1 feature class and report back true/false it is contained or not.
Can anyone point me in the right direction? Currently struggling to find an example. Much appreciated.
MattSayler
Unless there is some reason to use the geometry directly, I think the simplest way would be to use Select by Location using the "completely within" and "switch selection" options. Something like:
#Make Layers
arcpy.MakeFeatureLayer_management(perimeterFC, "perimeterLayer")
arcpy.MakeFeatureLayer_management(myFC, "myFCLayer")
#Perform Selection
arcpy.SelectLayerByLocation_management("myFCLayer", "COMPLETELY_WITHIN", "perimeterLayer", None, "SWITCH_SELECTION")
You could then loop through that selection (i.e. print the OID's) or export out to a new table/feature class.
