editing default base map
1174
12-05-2012 08:57 AM
ErikBlake
How do I edit my default base map in the "map" settings in "my organization". I go to edit settings-click on map. and the only option it gives me is the first map I made. I don't want any default map showing up when i create a new map. how do i reset it so no base map shows up in map unless I select one
Erik
MikeMinami
Esri Notable Contributor
All web maps must have a basemap. It's what sets the coordinate system of the web map. It is possible to add a layer and make it the basemap, effectively making a web map without one of the default basemaps.
the only other thing I can think of that 'may' work is to author an empty map service and make it the basemap. It may cause other issues, like what is the extent? No guarantee it will work.
Mike
ErikBlake
Miike.
I appreciate the response. I figured out what was going on.
