How to Start a new Pythonwin
2635
5
12-05-2012 05:36 AM
RoyDaniel
Hi all..:)
Does any one know how to start a new Pythonwin window, If I see from the start menu and then go to Python2.5 there are only as following:
- IDLE (Python GUI)
- Module Docs
- Python (command line)
and Python manuals
Hence until now I haven't found yet any Pythonwin button..
Thank you for any help
Best Regards,
V_StuartFoote
Roy,
If PythonWin is installed (it is not by default with the ArcGIS 9.3 or 9.3.1 you appear to be using) its executable would be in C:\Python25\Lib\site-packages\pythonwin\Pythonwin.exe
Simply create a shortcut for the executable, and place on the All Users or Public Desktop or Start Menu (depending on an XP or Vista/Win7 OS).
If not installed, the current builds of PyWin32 are available on SoruceForge here: http://sourceforge.net/projects/pywin32/files/pywin32/Build%20218/  I would no longer use the version included with the ArcGIS Desktop installation media set.
Since you are on Python25 be sure to get the pywin32-218.win32-py2.5.exe installer.
Stuart
RoyDaniel
Thank you very much Stuart..:)
RoyDaniel
Hi Stewart one question again, is that okey If "pywin32-218.win32-py2.5" to run in my windows 7 64 bit operating system ? or do we have py2.5 for 64 bit
Thanks a lot again..
Best Regards,
Roy
V_StuartFoote
Roy,
Use of 32-bit Python25 is built in to ArcGIS Desktop 9.3.x arcgisscripting library.  It will run without issue under WOW6432 emulation on 64-bit OS.
You could install a 64-bit Python as well, but ArcGIS would not use it.  Also, I don't believe the 218 build of PyWin32 for Python25 has a 64-bit flavor.
Since ArcGIS won't use it you could load a more current Python for 64-bit use if you go that route.
Just be aware, it can be a PITA to reconfigure between Python versions depending on your programming and sysadmin needs.
Stuart
RoyDaniel
Okey.. I understand Stuart.. I will try as your explain.. and of course this is very valuable..
Thanks again for your help
Cheers..:)
Roy
