Copying point location into new feature class
1025
12-04-2012 03:30 AM
KevinYanuk
Hello;
I am trying to grab point features from an existing point layer (feature class), and add a new point feature into a different feature class at that location (based on irrelevant criterion).
What I have creates new features, however, It puts all the features on top of each other at a single location, far away from the actual points I got the geometry from.  My code:
IFeature newConflict = fc.CreateFeature(); //feature class to create feature
newConflict.Shape = mFeat.Shape;  //mFeat is where I am pulling data from into newConflict
newConflict.Shape.SpatialReference = mFeat.Shape.SpatialReference;
//check for field, then add values
if (newConflict.Fields.FindField(FieldName) != -1)
    if (Value != null) Feature.set_Value(newConflict.Fields.FindField(FieldName), Value);
    else Feature.set_Value(newConflict.Fields.FindField(FieldName), DBNull.Value);
newConflict.Store();
Does feature.Shape not have contain location?  I thought it was complete geometry.
Do I need to manually store the Shape into the Shape field?
Thank you
MarcinDruzgala
As I understand this you just set the value for an empty feature in newConflict , you don't copy the feature.
Can't you just use Append? I really depends in what conditions you want to copy the feature(is it selected? etc).
(lest assume we have declared IFeature feature and it is point feature, I will skip few things just to show you example)
IPoint point = (IPoint)feature.Shape;
//now you can get the x,y and z values from it
double x = point.X;
double y = point.Y;
double z = point.Z;
Use Append Class form DataManagementTools to append feature into new featurelayer(the attributes will be copied as well).
tip - > it's easier to read the code this way:
    if (Value != null)
    else
SteveFang
From what you're describing make sure you destination featureclass has the same spatial domain and coordinate system is the same as your source featureclass.  I don't know if you need the spatialreference line.
